TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Error 36c9 on my 335i
      05-05-2018, 07:56 PM   #1
Guibibi
Drives: 2011 335i XDrive
Hey guys, just bought an 335i not long ago. Now everything at first was good, but since this week when going WOT, the car will give a jerk and will throw itself in limp mode. I scanned and this are the codes that comes up:
View post on imgur.com
Also at around 2-3k rpms, I have like a vacuum sound that comes up, could that be an boost leak?
If anyone could help that would be great!
      05-06-2018, 12:52 AM   #2
jiatistuta
Drives: 2011 335i Coupe
Same code, with some other codes related to boost leak. I replaced the fuel pressure sensor but the error code remains. I think 36c9 is caused by boost leak. I will change pressure converter and see what happens.
      05-06-2018, 10:49 AM   #3
Guibibi
Yea I might go ahead and go to an euro shop and do an boost leak test. Also I gathered a log from a pull that went in limp mode if anyone wants to give it a look .https://datazap.me/u/guibibi/36c9-lo...rk=65&hg=1-5-4
      07-09-2019, 12:00 AM   #4
wynes
wynes's Avatar
10
Drives: BMW 335i
Hey, did you guys sort the 36c9 code?
Cheers
      07-09-2019, 05:29 AM   #5
DiFFv1
DiFFv1's Avatar
Drives: 335i l 328xi l X5M
Any idle issues? Or trouble during cold starts?
"Proud Waitress At Gapplebees"
      07-09-2019, 11:24 PM   #6
wynes
wynes's Avatar
10
Drives: BMW 335i
NO issue on cold starts for me.
This only happens when im WOT in 3rd gear about 3000 RPM, car loses power and goes into limp mode, 36c9 is the code it throws (just as OP).
      07-10-2019, 10:03 AM   #7
B58guy
14
Drives: .
I had the same issue, took the car to a local bmw specialist and they are 90% sure it's the actuator. Getting it changed next week so will see if it fixes the problem
      07-10-2019, 06:48 PM   #8
wynes
wynes's Avatar
10
Drives: BMW 335i
nice.. let us know how it goes.
      07-13-2019, 01:44 PM   #9
EVC
EVC's Avatar
Drives: 2013 335i N55
I just had the 36C9 death code in the middle of a busy road. What fun. No power and wouldn't come out of limp mode until it was restarted. I'm running a burger intake, VRSF Intercooler and JB4 on Map-2 with a stick turbo. I find it hard to believe I've come anywhere near the fuel volume limit.
My first thought was the JB4 messed up but after reading this and other threads.
If anyone finds a cause and/or solution please post. I'm at a loss.
2013 335i M Sport
      07-28-2019, 02:33 PM   #10
wynes
wynes's Avatar
10
Drives: BMW 335i
Hey man.. did you manage to get this fixed?
Cheers
      07-29-2019, 11:16 AM   #11
B58guy
14
Drives: .
Cheers
We'll both find out tomorrow
      08-01-2019, 07:27 PM   #12
tman68
Member
tman68's Avatar
Drives: E90 335i xdrive, F15 X5
I have the same code. Give us an update on whether it's fixed or not.
      08-04-2019, 10:46 AM   #13
B58guy
14
Drives: .
I had a boost leak, get a smoke test done and it'll tell you if there's a leak anywhere
      08-05-2019, 07:28 PM   #14
Altria
New Zealand
Drives: E82 135i
Following, just got this code today known I have a boost leak. I'll fix the leak soon and see if it goes away
      04-02-2022, 06:00 PM   #15
PeterJaz
Drives: 340i
Bumping this old thread, i have the same issue. E92 n55, car runs perfectly fine except for at WOT there’s a bit of hesitation and sometimes (not always) it will go into limp mode with code 36c9.
I changed the fuel rail pressure sensor today, car still has some hesitation and I predict will re go into limp mode. No other codes.
I’m guessing it must be my hpfp? Some people said boost solenoid…any help on this would be appreciated before ai bite the bullet on a new hpfp.
Thanks
