05-05-2018, 12:50 PM | #1 |
756
Rep 2,149
Bad ceramic coating application
05-05-2018, 02:34 PM | #2 |
140
Rep 169
Wow that looks like shit, try reapplying the coating and wipe off just before hazing, you can also try Carpro essence plus by hand or orbital at the lowest speed.
05-05-2018, 09:11 PM | #3 |
756
Rep 2,149
Yes the issue is that the coating was let dry too long. Re-applying without removing what's already there first won't help. Not sure if that's what you were implying. Also the car is wrapped in Xpel and I'm unsure how it holds up to orbitals and polish.
05-06-2018, 01:07 AM | #4 |
140
Rep 169
Reapplying may help to reactivate and fix depending on how long its been on the car, if you have some left over it's worth a try. When I did mine I had some hazing on some parts and reapplying fixed it. The Essence plus also helps fix ceramic coatings and is not a abrasive, I understand your car is wrapped thats why I suggested you do it by hand or set your polisher at a low speed.
05-06-2018, 03:47 PM | #5 |
3684
Rep 2,955
What brand of coating? I assume you used a consumer version that's probably only good for 1-3 years. Even at that the streaks will remain until it's polished off or if when you replace the film.
05-07-2018, 12:32 AM | #7 |
756
Rep 2,149
CarPro CQuartz Ti02. You don't think the streaks will go away over time due to hand washing?
05-07-2018, 07:04 AM | #8 | |
80
Rep 257
Coating
Bruce |
05-07-2018, 07:06 AM | #9 | |
80
Rep 257
Coating over Xpel
I don't think you can wait this one out and or expect it to minimize over time. Bruce |
05-07-2018, 01:53 PM | #10 |
3684
Rep 2,955
Nope. The streaks will be there until you polish them off.
06-10-2018, 04:36 PM | #11 |
1418
Rep 2,559
Drives: Rapidly from A to B
What kind of polish to remove? I just used some gyeon cancoat on an Acura and had some streaking. I've had good luck in the past with the product so apparently just screwed it up this time. Finishing polish I assume. Nothing deep cutting. Correct?
06-12-2018, 11:28 AM | #12 |
3276
Rep 3,254
When I did my car there was a small section that I apparently forgot to level down which created the same streaking. Solution was pretty simple. Get some fine grade polishing compound and your DA and polish it down. Once done re-apply the cleaner to remove the polishing residue and repeat the coating.
Good luck. |
06-13-2018, 04:24 PM | #13 |
587
Rep 898
You can totally polish over xpel no problem. Just be light and go at a slower speed. It'll come right off.
I suggest using a more "flexible" coating such as a PHPs based coating like Gyeon MOHs, or vinyl specific coating like ceramic pro PPF/Vinyl for better durability and ease of application on PPF.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
