2006 330i w/75K miles burning oil at 1quart per 400-600miles
05-05-2018, 08:04 AM | #1 |
Rep 5
Hi all, I recently purchased my new to me 2006 330i One-Owner with 71K miles. Since then I have put four or so thousand miles on it and it has been burning oil like crazy. I'm afraid it may be rings and/or valve guides or seals. It is a MAJOR problem. The car doesn't smoke on startup or under every acceleration. The only time it smokes it when I accelerate quickly like using the button on the pedal or under load like brake/gas to spin the wheels. I've done a little test to see if it could be the PCV(remove oil cap for pressure) and there was none. One thing I will note that leads me to believe oil on spark plugs, is that start ups often take a second or two longer to crank. Other than this it really shows no actual symptoms of rings like lots of smoke and or loss of power the car feels strong and healthy. I just hope some of you'll could help me remedy this before to long. It is my only car and between work I don't have the time to be tearing it down to check plugs etc. I've used to treatments of Liqui-Moly motor oil saver to regenerate any "seals" but I know that it wouldn't help rings if that's the problem.
05-05-2018, 01:25 PM | #3 | |
Rep 5
So average 312.xx miles per quart. I need to figure this out I know just adding oil isn't really the best at almost $30 for a 5qt jug of Castrol Edge but I'm afraid it'll just get worse. Thought about running 5w-40 instead of 30 but have read the engines not designed for it |
05-06-2018, 08:55 AM | #4 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
You won't see the oil pan gasket leak under the car without taking off the belly pan.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
05-06-2018, 12:05 PM | #6 | |
2188
Rep 5,002
Given the high vacum conditions of your issue I second what hassmaschine says about the CCV system. |
05-06-2018, 01:21 PM | #7 | ||
996
Rep 2,287
Keep looking into your Crankcase Ventilation system. |
Noir883.00 |
05-06-2018, 02:17 PM | #8 |
883
Rep 1,413
Going off what was said above, if your car is "drinking" the oil and there is no oil stains in your driveway, 10/10 the crankcase ventilator valve is your culprit. Happened for me. I usually have to top off a quart if I am constantly getting on the car at 3k intervals. But when the new clutch was installed and I drove "normally" never burned a drop.
See you, space cowboy.
Supercharged |
05-06-2018, 07:37 PM | #9 |
1007
Rep 2,108
Plus one on the CCV. 1 qt per 500 miles, if it is a leak will eventually fill up the under belly cover and start to drip.
Your return tube on the CCV could have been plugged inside, if so oil coming from crank case won't be able to return back to the oil pan, and only other place it would go is through intake manifold back to engine and get burned up. The test to see if there is too much vacuum on the crankcase by opening the oil fill cap is a diagnosis for one failure mode of the CCV. The valve may be working which would not cause too much vacuum, but return line could be clogged. If you could take out the intake manifold you would fine good amount of oil in it if this is happening. |
05-08-2018, 10:20 AM | #10 |
180
Rep 772
Drives: 2015 435i grand coupe xdrive
while the car is running take the oil fill cap, see how much blow by it has.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
05-08-2018, 03:24 PM | #11 |
Crazy Frog
543
Rep 1,211
Don't forget the RMS. Those tend to leak too.
05-08-2018, 03:25 PM | #12 | |||
Crazy Frog
543
Rep 1,211
05-09-2018, 09:24 PM | #13 |
Rep 17
I will add to the chorus of people calling for the CCV. I also have an e90 330, with about 105k on it. Last fall it all of the sudden started sucking down oil. It had some leaks previously that were all replaced (oil filter housing, valve cover and oil pan). In about 800 miles after the valve cover and oil pan gaskets (I found broken aluminum "head bolts" while doing the valve cover) were replaced it nearly emptied itself of oil. When I replaced the CCV system the inside of the intake manifold was covered in oil so I knew I had found the culprit.
The CCV job is pretty easy, the biggest part of the job felt like getting all of the shrouds and covers etc out of the way. I've done a couple of thousand of miles since then without measurable loss of oil.
2006 330i
