Forged pistons for n55 ?
05-01-2018, 03:07 PM | #1 |
166
Rep 1,700
Im rebuilding my engine since i spun a bearing
Thoughts on JE forged pistons for cold climate ? Should i keep them oem but coat them to avoid slapping ? |
05-01-2018, 03:52 PM | #2 |
203
Rep 437
forge pistons comes with 2 types of alloy. 2618 with expands during heat and 4032 with does not expand as much as much with heat. but its not as strong. this info is important because 4032 forge piston could possible be as strong as the oem piston.
i run 2618 alloy forge piston in my 600whp 1.6 race car. knowing that i will be rebuilding this engine every season. |
05-01-2018, 04:17 PM | #3 | |
166
Rep 1,700
05-01-2018, 04:30 PM | #4 |
203
Rep 437
its best to do your own research. from my experience most engine builders just take your $$. after all there is no warranty for this stuff. good luck. IMO if your not building a race car stick to OEM.
the piston slap you mentioned is from loose PTW when engine warms up it goes away when warm.. if you dont get the PTW right it will expand right into the cylinder walls during high boost. this is not good for a daily driven vehicle. but perfect for a race car. https://en.wikipedia.org/wiki/Hypereutectic_piston |
05-01-2018, 05:17 PM | #5 | |
166
Rep 1,700
I just hope the rings will hold.... Ill do forged rods tho |
05-01-2018, 05:22 PM | #6 | |
203
Rep 437
you should be good with oem stuff. yes forge rods is a good idea. your engine build longevity will come down to tuning. the piston rings is atleast of your concern if its gapped right. it sounds like you will be running 93 pump octane. detonation and fuel quality will be your biggest concern. if you do run 93 you will face numerous hurdles that i cant begin to warn you about. good luck. |
05-01-2018, 05:25 PM | #7 | ||
166
Rep 1,700
i heard meth could have causs my spun bearing since it might have diluted my oil |
05-01-2018, 05:41 PM | #8 | |
203
Rep 437
i can get into detail of why that happened but its best for your to learn yourself and hopefully pass it down to others. because its your engine. if any of you guys want to test your knowledge of what you know please read this book https://www.amazon.com/Maximum-Boost.../dp/0837601606 if your not the type of reading and more to listening i will not take you seriously. |
05-01-2018, 06:07 PM | #9 | ||
166
Rep 1,700
my guess is that meth/alcool went by piston rings enough ( i sprayed A LOT ) that it diltued my oil and caused the spun bearing.... i like to read thats why i navigate between this forum and the bms one a lot thank you for your help |
05-01-2018, 06:26 PM | #10 | |
203
Rep 437
these are the same type of people that buy fast cars and think there racers because of what they read on the forum or what there told. real racers are people the build them and solve the issues. this takes R&D. this takes alot of $$$. your in a different position. i want to learn i honestly think if you had an oil pressure gauge you wouldnt have spun a bearing. If you knew what the acceptable oil presure was at idle and at 3k rpm and realized it was below spec you would have shut the car down and found out what was causing low oil pressure. this would require you to take the whole engine out and tear it apart. most people are not willing to do that. unless it was easy. no shop is willing to do this. unless they really wanted to help. you are the shop you are the warranty if not build it back to oem is all that im saying. keep your expectations reasonable towards your own ability |
05-01-2018, 07:12 PM | #11 | |
166
Rep 1,700
I can analyze logs and look for hints via apps and forums but for the rest id have to ask for help unfortunatly... And taking it back to oem isnt financially a good move The lowest mileage n55 available in a 2k miles radius is 60k mile and 4200$ cdn + 6 month warranty My rebuild is 7000$ cdn approx but the engine will be less prone to failure for my specific setup.. + 2 years unlimited miles warranty |
05-02-2018, 05:46 PM | #12 | |
718
Rep 1,753
When you say ALOT of METH what is ALOT. what system were you using ? |
05-02-2018, 07:34 PM | #13 | |
166
Rep 1,700
Spraying from 6 psi to 19 psi I do a lot of 1-2-3-4 gears pull so i spray for a long time and often IMO Engine is on a pallet it will be shipped friday ! Well know soon enough ! |
05-03-2018, 10:32 AM | #14 |
392
Rep 2,367
Drives: 2011 335i
How common is the to spin a bearing in the n55
