N52 Long Crank
04-28-2018, 06:48 PM | #1 |
Rep 17
N52 Long Crank
Hello friends, how are you? My name is Luiz and I'm from Brazil, I'm facing a problem on my 325i 2011 with N52 engine. Gradually a long start, I have measured the fuel pressure regulator, spark plugs and coils all in order. The battery is new, the problem does not happen every time, but most of the time when the engine is hot and off is about thirty minutes, when I start, it takes three seconds. What can it be? Sorry if this topic has already been created. I'm very worried.
Video: |
04-28-2018, 07:06 PM | #2 | |
68
Rep 298
Drives: '16 330e
04-28-2018, 07:39 PM | #3 | |
Rep 17
Thank you so much, do you remember what topic they were talking about? |
04-28-2018, 08:51 PM | #4 |
2440
Rep 4,330
my long crank was the starter.
Johnny Boost323.50 E7J3F331.00 |
04-29-2018, 07:28 AM | #5 |
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
It was me, I had a slow crank problem. It was my ground cable and starter.
Your crank sounds very healthy. Scan INPA for codes |
04-29-2018, 11:51 AM | #6 |
1911
Rep 13,104
Check the battery and put a full charge on it first.
Then the other stuff. My starts were sluggish at the end of the battery life. If it is more sluggish on the first start of the day it indicates the battery is loosing charge overnight. |
04-29-2018, 05:28 PM | #7 | |
Rep 17
hello friend, I put a new 80mAh agm battery last week. |
06-28-2018, 09:51 AM | #10 |
2440
Rep 4,330
yeah, and as I stated, my long cranks were the starter.
have you tested the starter? checked all of the primary battery wiring? Checked the ground straps? Checked the voltage while cranking? it's not rocket surgery here, it's a 12V motor. |
Amherst0.00 |
08-10-2018, 07:11 PM | #11 |
Rep 17
08-10-2018, 07:12 PM | #12 | |
Rep 17
08-10-2018, 07:15 PM | #13 | |||
Rep 17
