Loud Suction at WOT
04-27-2018, 10:20 AM | #1 |
94
Rep 321
Loud Suction at WOT
I recently noticed a really loud suction at full acceleration coming from passenger side. There is no performance decrease from what I can tell. Under mild to heavier acceleration no issues. It only happens when i am at nearly 100% throttle. I don't see any oil leaks, my intercooler hoses are all connected. I have no codes. I do have a BMS intake, but this doesn't sound like it is coming from the intake. Has anyone ever ran into anything similar? Could the hot side charge pipe be damaged as it is plastic? If that was the case, there would probably be a code. Could it be a hose or bad boost solenoid? Any advice would help. Thanks!
I will try and get a video to post!
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned |
04-27-2018, 11:10 AM | #2 | |
BMW Portland
224
Rep 524
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
04-27-2018, 11:38 AM | #3 |
94
Rep 321
I was going to do a more thorough inspection once the weather gets warmer here and I get some time on the weekend. There are only so many things on the passenger side it could be coming from, so I should be able to find something.
04-27-2018, 02:35 PM | #4 |
BMW Portland
224
Rep 524
Most leaks that aren't a full disconnect are pretty hard to see, even if you have the car on a lift. I suggest doing a smoke test if you have the opportunity, it saves a ton of guess work.
04-30-2018, 10:44 AM | #5 |
94
Rep 321
Here is a sound clip:
Possibilities: Loose clamps, Boost solenoid, hot side charge pipe, tear in silicone intercooler hoses, turbo waste gate. Any other ideas?
Totaled:2014 Audi A4 CTS K04 APR Tuned Last edited by NRigs; 04-30-2018 at 11:31 AM.. |
E90joee147.00 |
04-30-2018, 07:13 PM | #6 |
94
Rep 321
Solved!
It was something I didn't expect. Since I had a nice day after work today I decided to look around and noticed an intercooler hose t-clamp was off. When I first installed my intercooler, the hose clamps would come off and I would have almost no power. That is why I didn't expect it to be the clamp. We are back in business!
