04-25-2018, 05:43 PM | #1 |
BMW obsessed
9548
Rep 10,844
IND | F90 M5 Trunk Spoiler | Installation Procedure
Step 1: Apply a solid border of tape around the trunk spoiler to create a barrier between the paint and factory spoiler. Step 2: Use the supplied piece of fishing line to work your way under the spoiler to remove it from the trunk. After traveling the length of the spoiler, you will be able to lift it away from the trunk. Step 3: Remove the excess residue and tape surround from the trunk to ensure a smooth paint surface onto which the 3D Design replacement can adhere. You can use a combination of adhesive remover and a light duty polisher for a finishing touch. Step 4: Clean the 3D Design trunk spoiler thoroughly and follow with a couple sweeps with the included adhesion promoter. Step 5: Apply the included double sided tape to the underside of the 3D Design trunk spoiler. Align the tape to both the bottom and top edges. Step 6: Test fit the 3D Design spoiler. Once satisfied with placement, tape the two edges and middle to hold it in place, and follow with a solid border of tape surround. This will help place the spoiler precisely once the double-sided tape is exposed. Step 7: With the tape border in place, set the spoiler aside and apply a coating of adhesive promoter. While drying, create pull tabs on the double sided tape. We recommend one piece on each edge, and two tabs in the middle. Step 8: With the spoiler set in place, expose the double-sided tape by pulling on each tab one by one. As each tab is removed, use uniform pressure to press the spoiler onto the OE trunk for good measure.
