3IM "4th DISA Stage Disable"
04-19-2018, 03:02 PM | #1 |
Resident Pedant
503
Rep 792
Didn't want to hijack the other thread. I can't find any threads devoted to this topic. Unsurprisingly searching for "4th stage disa disable" is not specific enough.
Part of the BPC tune? Can anyone share technical details?
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
04-19-2018, 03:16 PM | #2 |
401
Rep 1,425
04-19-2018, 05:05 PM | #4 | |
883
Rep 1,413
wish I had that. thanks for the info-
See you, space cowboy.
Supercharged |
04-19-2018, 06:04 PM | #5 |
Resident Pedant
503
Rep 792
Thanks as always, sir
04-19-2018, 06:35 PM | #8 | ||
883
Rep 1,413
Supercharged |
04-19-2018, 06:43 PM | #9 | |||
996
Rep 2,287
The engine pulls really great to 6,700. Considering it starts pulling several thousand RPM below that, you have a really nice long powerband. |
04-19-2018, 07:19 PM | #10 | ||||
883
Rep 1,413
just saying, having it push all the way to the limiter, would be thicc.
Supercharged |
04-19-2018, 08:38 PM | #11 |
Resident Pedant
503
Rep 792
FWIW the TIS says the redline in our cars is 6500 RPM
Noir883.00 |
04-19-2018, 10:10 PM | #13 |
Resident Pedant
503
Rep 792
It's not that I really believe it in this case, it's just that it's the only example of an incorrect redline in the whole TIS (as far as I've found) and I can't think of a compelling reason why this would happen. It's not a simple typo either, because the permissible constant RPM (6300) is where it would be if the redline were truly 6500 rpm. I wonder where the discrepancy arose.
I can find lots of literature re: 6500 RPM power peak but other than "the n52 electronic rev limiter is set at 7000 rpm" I am at a loss for references to 7K. Clearly the gauges indicate a 6750/7000 RPM constant/max.
Noir883.00 |
04-19-2018, 10:33 PM | #14 |
3973
Rep 7,215
The redline is programmed at 7k (give or take 20 rpm), that's what the engine will do. What the gage etc. says is meaningless really, since it's not perfectly accurate. On Auto cars, it's lower but only because the AT trans shifts before redline.
