FS: 2007 335i lots of maintenance and modifications
04-13-2018, 05:40 PM | #1 |
51
Rep 239
2007 BMW 335i
N54 Sport package, manual Logic 7 audio I purchased the car almost two years ago with around 107k miles, previous owner had not done much besides replace the oem turbos with new oem turbos around 98k miles and a hpfp and the car was stock. Since, I have done lots of preventative maintenance and repairs as needed I have receipts for everything I have bought from either bmw, or fcpeuro or ecs tuning or elsewhere. Car now has 124,500 miles and will slowly go up as I drive the car every other day Maintenance/repairs 112k- Replaced oil filter housing unit and gaskets as original had a small crack 115k- valve cover valve cover gasket oil pan gasket index 12 injectors Tensioner, idler pulleys and belt Air conditioning serviced Delphi coils Ngk 95770 spark plugs 119k- Spec stage 2+ clutch, spec single mass flywheel. (stock clutch could no longer hold the power the car was making) 122k- Water pump and thermostat Both new boost solenoids and vacuum lines Coolant expansion tank and cap Oil changes every 3-3.5k miles Modifications VRSF Chargepipe w/ tial bov VRSF Catless downpipes Custom straight piped exhaust made on stock exhaust, secondary cats deleted, resonator replaced with magnaflow xpipe and PE modded mufflers. RB PCV valve Mishimoto baffled oil catch can lowered on lowering springs stoptech street brake pads Pinnacle Specialty Performance 600ic front mount intercooler with lower chargepipe EuroTuningGroup Stage 2 bucketless fuel pump walbro 450 N20 Tmap sensor MMP turbo inlets Spec Stage 2+ Clutch disk and pressure plate Spec single mass steel flywheel RTD Mini V2 Chassis mounted race shifter with dual shear selector rod Tuned with MHD. Currently working with Twisted Tuning with a custom tune for my car. Apex Arc-8 wheels 18x9 front 18x9.5 rear. new summer tires all around 245/35/18 front and 265/35/18. Just purchased the wheels and tires in January this year. Some older pictures I posted have my old bbs replica wheels which I no longer have, the shinny silver ones. Car will come with oem bumper that fits well. m3 rep in pictures is not same black and does not fit the best. $12,900 will entertain offers. no trades. Any questions please call or text me 610-570-9seven98 Located in Downingtown, PA 19335 |
