Engine misfire
04-11-2018, 07:39 PM | #1 |
Rep 19
Engine misfire
I’ve gotten codes p29d2, p2e18, and P29cd. I just replaced the coil pack for cylinder 1 probably 5000 miles ago now it’s misfiring again. I tried to replace the coilpack for 6 still misfiring. Also I can’t find anything on the code p2e18. Need some help finding out what’s wrong.
04-11-2018, 07:43 PM | #2 |
157
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
What’s the mileage on this car?
Have you replaced the plugs?
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
04-11-2018, 07:48 PM | #3 |
Rep 19
04-11-2018, 08:27 PM | #4 | |
Rep 40
Drives: 2009 335i xdrive
There was a thread with the same P2E18 code a while back and it seemed to be "fixed" in a weird way if you want to take a look.. http://www.e90post.com/forums/showthread.php?t=1457713 |
04-11-2018, 08:39 PM | #5 | |
157
Rep 848
I would inspect the wiring to the ignition coils as well. Coils then plugs are the first things you should check for a misfire. I would go ahead and replace all the plugs, but swapping just the one should be sufficient to fix the issue.
04-15-2018, 11:34 AM | #7 | |
4277
Rep 9,209
