04-11-2018, 03:57 AM | #1 |
105
Rep 280
M2 Competition Intercooler
Do you guys think the M2 Competition will have the Air/Liquid top mount intercooler from the M3/M4, or a new Air/Air front mount intercooler?
The leaked press release states: 'Weight optimized Bi-Turbo for maximum power build up.' Case for Air-Air FMIC: -Lighter, so fits the 'weight optimized' part of the leaked release -No hood bump: is the hood bump required to fit the air/liquid TMIC? Case for Air/Liquid TMIC: -Less design work for BMW as the TMIC has already been optimized/tuned for the S55 ***** Additionally, would you prefer the weight savings of the FMIC, or the increased cooling/potentially more aggressive tuning available with the TMIC for an M2 sized car? |
04-11-2018, 06:53 AM | #2 |
3179
Rep 2,577
I suspect weight optimized and quicker build up mean smaller turbos, not cooling method.
Smaller turbos alone are more than enough to restrict power. For example strap a pair of N54 turbo so you have a S55 that's even a tad weaker than M2 N55. I doubt BMW would go this far - engineer/make new intake plumbing and A2A IC core (sure it has to be bigger than M2/M235), just to hold M2 Comp back. Again not even necessary to begin with from power standpoint. Nor is the 'weight saving' from A2A IC worth the hassle. But you never know, from the cost perspective, maybe they can recoup engineering/tooling of new cooling parts from the entire production life, because at the end of day A2A is cheaper to make.
Lemania 2320
Tag18128.00 |
04-11-2018, 02:59 PM | #4 |
10583
Rep 6,920
Drives: 2018 M2 AW DCT
I think it is just one of the many questions that won’t be answered until someone actually gets to look under the hood.
04-11-2018, 04:46 PM | #6 | |
this is the way
18128
Rep 8,514
If anyone has an M3/4 and can confirm this please do! |
JTO245271.50 |
04-11-2018, 04:47 PM | #7 |
1040
Rep 3,622
That’s what I think, it’s just a marketing fluff statement. I don’t even think the statement was even referring to turbos specifically, but rather the “Bi-turbo” S55 as a whole. Meaning the the Bi-turbo engine is weight optimized and we already know it is.
04-11-2018, 05:14 PM | #8 | |
4143
Rep 6,926
For comparison the top mount intercooler on the S55 doesn't sit any higher than the B58 engine cover. The intercooler is not even the high point, the reservoir filler cap is the highest point. Which is an easy item to relocate, which I don't even think would be needed. The M2 hood looks to have plenty of room to accommodate the top mount intercooler. Last edited by hellrotm; 04-11-2018 at 05:20 PM.. |
04-11-2018, 05:30 PM | #10 |
4143
Rep 6,926
There is also space constraint, I don't think there is room for a front mount using the S55. They already had to lay down the oil cooler, which led to some failures when cars ran over large debris on road.
Personally I think it is more likely they retain the top mount. S55 cooling setup |
04-11-2018, 06:10 PM | #11 | |
119
Rep 163
04-11-2018, 06:13 PM | #12 | |
119
Rep 163
04-11-2018, 06:15 PM | #13 |
this is the way
18128
Rep 8,514
04-11-2018, 06:25 PM | #14 |
119
Rep 163
04-11-2018, 06:47 PM | #15 | |
2453
Rep 2,706
04-11-2018, 06:59 PM | #16 |
7333
Rep 7,294
95% chance it is exactly the same as in M3/M4. It is too much work to modify and re-validate the setup for a short lifecycle product like the M2 Comp. It defeats the purpose of reusing the hardware as it is.
Chako105.00 M3 Adjuster7904.50 |
04-11-2018, 08:31 PM | #17 |
340
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
Who knows what the marketing guys refer too! Do they even know what they are talking about? to wit.... the early "reinforced block" marketing hype of the N55 M2 motor..which turned out to be quite the hype (i.e. lie)
04-12-2018, 10:27 PM | #18 | |
2026
Rep 2,671
Also the tq output appears to be the same - thx BMW! This tells us most likely the turbos are the same. I doubt BMW would spend additional funds on R&D to redesign parts of S55. It takes a long time to perform environmental, stress and reliability testing. However, they need to decrease hp output slightly to keep marketing dept happy. Also, new M3 w/S58 is around the corner so M2 positioning with "old" S55 will work fine for marketing next gen M3/4. |
04-13-2018, 03:13 AM | #19 | |
1120
Rep 1,644
04-13-2018, 07:26 AM | #20 |
never could compete with Lloyd Braun
5272
Rep 5,378
S55s have already been fit into tuner M2s without new hoods. I believe the M2c will get the same set-up as the M3/4
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
04-13-2018, 07:36 AM | #21 |
7905
Rep 11,785
@homerdog posted that the weight is up 55Kg. ( 110lbs) for the M2 Competition due to extra cooling capacity.
Seems like the top cooling set up would be part of this. |
04-13-2018, 07:36 AM | #22 |
119
Rep 163
The primary reason I got excited about the M2 Comp, and am #5 on my dealers waiting list, is the S55 engine. The detuning which reduces the hp in the M2 Comp below the M3/M4 S55 hp is very slight and done for the purposes of marketing sales for both the M2 Comp and M3/M4. It would be poor marketing for the M2 Comp to have greater hp than the pricier M3/M4. The de-tuning is accomplished by software tuning and not hardware changes therefore the M2 Comp will easily be re-tuned to increase hp and torque. And of course this is something that I intend to do with my new car.
