Over boost codes
04-09-2018, 07:40 PM | #1 |
14
Rep 41
Over boost codes
Hi everyone, I'm consistently getting overboost codes and half engine codes when I accelerate from a low rpm. I recently removed my vacuum canisters because I broke one of the nipples for the hose when I was relocating them for my inlets and outlets. Would this cause an overboost code or would that be leaning more towards boost solenoids? It's driving me crazy, I have full boost on full pulls though and goes back to normal when I restart the car. Any help is appreciated thank you
04-10-2018, 09:02 AM | #2 |
26
Rep 142
i haven't performed canister delete but it's well documented many have deleted it without any noticeable issue. if you are getting codes, i would suspect you have a large tear in a line. the two lines that go to canister are famous for disintegrating where they connect to the vacuum pump line.
