04-09-2018, 11:34 AM | #1 |
471
Rep 682
Taillights are a magnet for leaf gunk.
Every time I wash the car I dry around the trunk and notice a few little leaves and whatnot get in the crack at the top of the taillight. The way the car's designed this is pretty much inevitable. Today I popped off the tails and gave it a real cleaning. There WERE leaves in there I couldn't get to without removing the tails. These cars are new and not rusting yet, but I know that leaves and dirt are moisture magnets so I figure this is something I'll do every 6 months or so.
Easy to pop off. 2 nuts and a good pull and they pop right out. 2 wire plugs and they're completely off the car and you can throw them in the dishwasher for a good cleaning. Kidding on that part.
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT 2013 Porsche Boxster S |
04-10-2018, 07:29 AM | #3 |
471
Rep 682
Re are 2 little plastic doors one of which you can see in my first pic. Just pop those open and get in there with a 10mm socket on an extension.
You have to give the light a reasonable yank to pull it out. The front corner is held in by a pin and grommet type gig. Remember there are wires attached, so when it lets go, don’t end up on the other side of the garage. There’s actually a handhold on the inside edge of the light so you can get a better grip. When you put them back on, a little bump with of heel of your palm will reseat the grommet and pin. I knew how to remove them from when I changed my tail bulbs to LEDs. It’s easy. Good luck.
emargul204.50 ///MPhatic13846.50 |
04-10-2018, 08:24 AM | #4 | |
205
Rep 316
04-10-2018, 08:49 AM | #5 | |
2087
Rep 3,005
04-12-2018, 09:05 PM | #6 |
724
Rep 1,756
The leaf trapping tails are nothing new on BMWs. My e39s always trap leaves as well as my Z3 roadster. My oldest will be 20 yrs old this October, and it's not rusting behind the tails.
2016 428ix, r, 2018 430iC, 2018 330it
spencers199.00 |
04-13-2018, 06:43 AM | #7 |
80
Rep 257
Its also a good idea to every so often to pull your front inner wheel well plastic and clean out those. We pulled some on an M3 and lots of junk came out from the cowl drainage and motor drainage.
Bruce |
09-14-2022, 09:54 PM | #8 |
67
Rep 126
Resurrecting this thread; there's a massive tree right above my parking, so this spot is always full of leaves and other organic stuff. I don't feel like removing my tail lights every 2 months so I'm thinking to put a silicone bead at the upper junction between the lights and the body. Anyone did this?
09-15-2022, 01:44 AM | #9 |
844
Rep 1,962
As the gap between the light moulding and the body appears to be the drain for the channel around the trunk lid (which is why the leaves end up in there), might that not cause other problems?
09-15-2022, 07:58 PM | #10 | |
67
Rep 126
09-15-2022, 08:23 PM | #11 |
The Seeker
13847
Rep 3,319
Man I hate this spot. This thread has inspired me to take the tails out and clean that area properly since it's no longer my daily. I have to do the same thing to my fender liners.
11-26-2022, 07:31 AM | #12 |
246
Rep 715
Drives: 2021 X3 M40i
I've been reading that the taillights develop a short because of a bad ground. Since the connecting plug is on the backside of the taillight, this plug is actually exposed to the water running down from the trunk drainage. I know this because I am dealing with this problem right now. Can't seal the top because then it will be stuck to the car so once I get it fixed (of course it had to happen on Thanksgiving weekend when my Indy shop is closed), I'm going to find a way to wrap and seal the plug. It's a really bad design IMO but what are you going to do?
