The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Polyurethane bushings?
      03-11-2006, 02:03 PM   #1
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Does the 330i sport package come with polyurethane bushings, or are they rubber?
Nikki
      03-11-2006, 02:46 PM   #2
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
I believe they are rubber. Poly dries up really fast and squeeks if not lubed on a regular basis.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      03-11-2006, 03:06 PM   #3
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Danny
most good polyurethane bushings have slots that hold grease in them and they're guaranteed not to squeek lifetime.
Nikki
      03-11-2006, 03:37 PM   #4
ward
155
Drives: F
I had poly bushings on my aftermarket sway's on my old E30 and after a couple of years they did start to squeak pretty bad.
Some of the nicer kits have a fitting to lube the bushings though (my RD bars didn't though)
      03-11-2006, 04:26 PM   #5
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
I had neuspeed bars and they had slots in the bushings, and over a period of time, started to make noise...in every car I had them in.
Danny
      03-11-2006, 08:00 PM   #6
larryn
The stock swaybar bushings are a rubber compound. Aftermarket are generally polyurethane. I've had UUC and RD Sport sways on previous bimmers, and they always needed an annual relubing. I think some are getting better, with grease fittings, but they still need regular maintenance.
The end-links also made noise after a while. I had to replace one set of UUC end links after they got contaminants in the ball sleeve (I think it was sand) and nearly seized. I would service them annually as well.
Even with the maintenance, they are totally worth it, if you track or autox your car.
      03-11-2006, 09:46 PM   #7
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
thanks for the info everyone
Nikki
