Oil in Vacuum Lines
04-05-2018, 07:37 PM | #1 |
139
Rep 227
Oil in Vacuum Lines
So I went to change my vacuum lines and found the two coming from the valve cover to the pressure converter/exhaust flap filled with oil. Can't seem to find much information on the internet or the forums here. Only thing I found is pointing to the vacuum pump pumping oil through the system. I just would like to be sure there's not a seal or gasket that can be replaced or if I just need to buy a new vacuum pump. I'm gonna check the vacuum supply line to the valve cover tomorrow to see if it is also filled with oil just to be sure.
Anyone else have this problem? |
09-22-2019, 12:21 AM | #2 |
166
Rep 429
Drives: 2011 e92 335xi
Did you ever figure this out?
Mine's getting worse.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
09-22-2019, 12:42 AM | #3 |
166
Rep 429
PCV failing?
09-23-2019, 02:52 PM | #4 |
139
Rep 227
I never really looked too far into it since my motor was performing fine. I had eventually come to the conclusion that the valve cover is just bad, but that's purely on a hunch. Maybe a hairline crack in the vacuum reservoir that allows oil to creep in. I didn't have any other symptoms of a PCV failure like excessive vacuum on the oil cap. It was just oil in the vacuum lines.
Supermoon166.00 |
10-04-2019, 02:47 AM | #5 |
166
Rep 429
My valve cover was fine.
It turned out to be a leaking diaphragm in the vacuum pump. Pics: https://bmwtechnician.com/2016/02/22...p-n54-and-n55/ Replacing the vacuum pump is fairly challenging: https://www.newtis.info/tisv2/a/en/e...-pump/EIj0QQaf The pump is $500+ and the labor costs just as much.
10-04-2019, 09:22 AM | #6 | |
2659
Rep 6,290
10-08-2019, 10:29 AM | #7 |
139
Rep 227
TheMidnightNarwhal2658.50 TheGoodTheBadTheUgly257.00 |
03-03-2021, 10:49 PM | #8 |
528
Rep 1,165
Drives: 09 E92 335i 6MT
Long shot but what ever happened with this car? I believe my pump diaphragm has begun leaking. I can do the job but dont exactly have time atm. Wondering how long ive got lol
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
