n55 jumped timing
04-04-2018, 11:46 AM | #1 |
166
Rep 1,700
n55 jumped timing
well my indy is inspecting the car after i did a pull on ps2 at 19 psi ( logs look clean) ( first day after i pick up the car ) and i got these codes. plug 1 was melted and cam sproket was off. hes changing the hub. the tensioner . plugs and cam sprokets and hopes it fixes it..
compression is 75 psi on all 6 cylinders so he thinks valves are ok and not bent but not fully opened cause of timing off.... thoughts ? UPDATE : it was a slippy tensionner, spun hub and broken cam sprokets !! Retimed engine and all is perfect !!! THANK YOU EVEYBODY ! FINAL UPDATE : ok here is exactly what happened. when i brought the car for timing chain issues i had a melted plug on cylinder no 1. indy was curious to why it happened....it made the chain skip and timing off timing was fixed with new parts ( timing chain tensionner etc... ) After a 2 days i did a pull in 3rd gear from 2.5k rpm to 6.5k rpm and the log looked perfect but after i had rod knock noise. i brought it back to indy and on cyl 1 there was a spun bearing and slightly bend rod ( metal shavings everywhere ) so originally i guess was my bearing was going out slowly on cyl 1 im gettin a rebuild by MMP ( forged rods and pistons with coated bearings.....) the best used engine i could find was 75k miles and from a sketchy place. Im scared this engine would do the same too at my power level so im going with a nice rebuild.... lmk if you have any questions Last edited by Bours; 04-26-2018 at 07:27 AM.. |
04-04-2018, 11:50 AM | #3 |
166
Rep 1,700
04-04-2018, 12:28 PM | #4 |
718
Rep 1,753
If you dont mind what oil were you using. Also weight brand and interval. Just curious.
The good thing here is that your compression is equal across all cylinders even though its very low. |
04-04-2018, 12:30 PM | #5 |
718
Rep 1,753
04-04-2018, 12:33 PM | #6 | |
166
Rep 1,700
liqui moly 5w-40 5k miles interval religiously |
04-04-2018, 12:43 PM | #7 |
718
Rep 1,753
Absolutely its a good sign. IT means that you dont have seal issues or ring issues or bent rods and such big problems.. I suspect the variable timing mechanism..which i believe relies heavily on oil pressure to operate.. Did you do a vanos bolt recall ?
04-04-2018, 12:44 PM | #8 |
718
Rep 1,753
I would also not neglect sensor issues.. like cam sensor or crank..
04-04-2018, 02:04 PM | #9 |
1161
Rep 3,189
He said the actual timing was off, as in jumped timing. Oil and vanos would have nothing to do with this. It is a known issue with all N54, N55, S55 since they share the same hub.
If your mechanic did the compression test before fixing timing and the hub, maybe 75psi is fine. If he checked after then it is not fine. |
04-04-2018, 02:43 PM | #10 | |
166
Rep 1,700
04-04-2018, 02:48 PM | #11 | |
166
Rep 1,700
04-04-2018, 05:14 PM | #12 |
718
Rep 1,753
04-04-2018, 06:47 PM | #13 |
166
Rep 1,700
he doesnt know if they are ok...hes gotta to remove the head to check em....but since compression is equal on all cylinders he will fix cam sprokets. tensioner and hub then hopes it fixes everything.....
04-05-2018, 09:11 AM | #14 |
1207
Rep 2,026
[ignore this erroneous statement] There is piston to valve clearance...
04-05-2018, 11:28 AM | #15 |
166
Rep 1,700
04-05-2018, 12:33 PM | #16 |
718
Rep 1,753
04-05-2018, 12:36 PM | #17 |
1161
Rep 3,189
Testing valvetronic is irrelevant to his issue. Bbkns2 just stated it from a valve to piston clearance stand point. From what I have seen if that if you jump 2 teeth you should be fine. 3 and you are probably done.
bbnks21206.50 |
04-05-2018, 02:34 PM | #19 |
166
Rep 1,700
04-05-2018, 03:24 PM | #20 | |
718
Rep 1,753
But its likely that something is up with the vanos or valvetronic motor. Variable valve lift and variable valve timing control all valves at once.. which makes sense more than individual valve issues.. compression is the same.. |
04-05-2018, 03:26 PM | #21 | |
166
Rep 1,700
04-05-2018, 03:59 PM | #22 |
132
Rep 573
i keep reading more and more hub issues as cars get older. Ridiculous design by Bmw to not key the crank and sprockets and rely on frictions discs, but at the same time lots or torque at low rpms isn't helping.
