Engine Fan Goes on and off often
04-04-2018, 09:50 AM | #1 |
Rep 50
Question I had a problem with the fan staying stuck at high. I took it in and had water pump replaced and thermostat. I haven't had the car a year as I purchased it used but should the fan go off and on so frequently with the AC? I notice it doesn't go on as often when the AC is off. Maybe I'm just paranoid lol since the water pump was replaced. I live in Miami
I have 328 2011 Coupe Sports Pkg. Thanks for any input. Ill double check the coolant and the coolant level seems fine. The stick floats out above min. |
04-04-2018, 12:31 PM | #2 |
2188
Rep 5,002
It will cycle more with the AC. Sounds normal.
If it sounds like a jet engine all the time then there’s an issue, but you are in FL where it’s going to be on more than the average fan. |
04-14-2018, 10:26 PM | #5 |
298
Rep 4,040
Drives: 130i coupé ;)
This is Thermostat related. Consider Water pump replace as well to avoid repeat work.
I changed mine last summer.
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
TGSN_30.00 |
04-15-2018, 06:37 PM | #6 |
65
Rep 195
Drives: BMW,Tesla, etc.
Scan with ISTA/D to see any "pending" codes. If you have none, then everything is under normal operation...otherwise if you get codes, it may be for the t-stat or water pump.
04-24-2018, 01:41 PM | #8 |
Rep 50
Oddly this only happens when the AC is turned on and goes the sound subsides for a few minutes at times but comes on.. Ill pull codes maybe its me being me lol
04-24-2018, 06:38 PM | #9 |
Rep 50
https://drive.google.com/file/d/19Hr...ew?usp=sharing
i also tested the water pump and no errors. AC on AC ON and OFF AC off Fan idle slowing down Last edited by jcruiz73; 04-24-2018 at 07:14 PM.. |
04-24-2018, 07:16 PM | #10 |
Rep 50
Water pump and T was replaced 2 months ago by a mech. I am going to call them to check it out again.
Also if i drive for a while it will idle down but once i stop eventually gets loud with AC only on Last edited by jcruiz73; 04-24-2018 at 08:07 PM.. |
05-07-2018, 08:36 PM | #11 |
Rep 50
Took it to the Dealer seems that fan is working fine. I did take it to AC shop and since i just had a new compressor installed a month ago or they drained refrigerant and add a little some oil.
