Datalog...What's Wrong?
04-03-2018, 07:09 PM | #1 |
123
Rep 109
E90 Experts – 2011 335i n55 that my tuner and I are trying to tune. Nothing crazy, just looking for a nice, safe power gain with reliability. The car has a VRSF 5” stepped intercooler and upgraded charge pipe.
The log referenced below is based on the Cobb 1+ and is on Rev 1 from the tuner (91 octane). The tuner thinks I have a leak based on the fact that boost builds initially, then drops off, then builds again before tapering as normal. I have been through all connections twice and replaced the CP-to-throttle body o-ring. I also have a boost solenoid on order, in case that’s the culprit. Any suggestions from folks who have been doing this longer than I have? Anything else look particularly wrong with the log? Thanks for the assistance! https://www.dropbox.com/s/gac9ya8o9v...20WOT.csv?dl=0 Last edited by fatty335; 04-04-2018 at 08:29 AM.. Reason: Wrong link |
04-06-2018, 05:49 PM | #3 |
123
Rep 109
UPDATE: Replaced the boost solenoid last night and accomplished a short pull to 4k rpm since, during the last log, boost had recovered to ~15 psi by then...and it was even worse! Boost never got above 9! I just don't understand it - the car pulls hard and feels good. Has anyone ever heard of the boost pressure sensor in the CP going bad or reporting bad pressure data? The car is not throwing any codes at all. Suggestions?
04-08-2018, 03:19 PM | #4 |
123
Rep 109
UPDATE: Well folks, problem solved! Put a brand new boost pressure sensor in and logged it - rock solid 16 psi again! So, if anyone ever has boost that's not hitting target and are sure there are no leaks, try the pressure sensor.
04-08-2018, 06:35 PM | #5 |
115
Rep 127
04-09-2018, 12:01 AM | #6 |
78
Rep 239
If he means boost solenoid, then its the sensor on turbo side of engine. Near the valve cover with a metal clip that you push in. A lot of heat shields in that area
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703 |
04-10-2018, 01:13 PM | #7 |
40
Rep 177
04-10-2018, 01:16 PM | #8 | |
78
Rep 239
04-10-2018, 03:29 PM | #9 |
123
Rep 109
