MHD flasher keeps failing, please help!
03-29-2018, 11:52 AM | #1 |
Rep 27
Hey guys, I've been trying to flash my 07 335i with msd81(built date 11/06) with MHD Flasher and every time I get the message "failed to write ecu. Unable to erase memory". I'm using the recommended cable and otg from bimmergeeks and have tried 3 different Android devices. I also have a cheap ebay cable and otg that I tried as well and I'm still getting the same failed message. Ignition is on, device in airplane mode, and I'm using a legit battery charger capable of 200a. The first couple of times I tried flashing with MHD I was using my cheap ebay stuff, so I bought new cable/otg from bimmergeeks and its still doing the same thing. I've spent around $200 for the licenses and cables and still can't get the thing tuned. What the hell am I doing wrong, anybody have any ideas?
03-29-2018, 12:00 PM | #2 |
521
Rep 1,484
you on android 7? you also in airplane mode? if you have a case, take the phone out of the case. sometimes the case prevents a complete usb connection.
which devices have you tried it on
Current Ride=2008 BMW 335xi
2017 BMW M240 Xdrive 2017 BMW M2 N55 6spd 2018 Infiniti Q60 Redsport AWD 2008 BMW 335ix |
03-29-2018, 12:04 PM | #3 | |
Rep 27
S6 on 6.0.1, my wife's s6 active on 7, and my old g3 on 6.0.1 Neither phone was in a case, and all 3 were in airplane mode |
03-29-2018, 10:48 PM | #5 |
521
Rep 1,484
sorry my post from earlier didn't go through. i was able to flash it...on note 8, stock 7.1 rom, with developer options off on ebay kdcan cable at 85% charge.
are you at least at 80% battery? are you able to connect to the dme with the cable, such as reading codes using the app? maybe try uninstalling and reinstall the app. |
03-30-2018, 05:52 AM | #6 | |
Rep 27
03-30-2018, 11:56 PM | #7 |
521
Rep 1,484
did you buy this car used? uhmmm you sure the car wasnt tuned before? i know cobb locks there tunes until you unmarry the dme from the cobb and its back to stock.
you try some of the older maps like version 6? |
03-31-2018, 08:52 AM | #8 | |
Rep 27
Also have tried v6 and v8 as well |
03-31-2018, 09:09 AM | #9 |
648
Rep 2,015
If the car is running, i would think mhd can log it and that would answer if it its tuned or not. Also read codes on mhd would help.
335i e92 TPC 19Ts
03-31-2018, 09:43 AM | #10 |
Rep 27
03-31-2018, 11:23 AM | #11 |
ahat
1036
Rep 2,592
weren't you the one that the presumption was it was write protected?
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
03-31-2018, 11:27 AM | #12 |
Rep 27
03-31-2018, 11:30 AM | #13 |
ahat
1036
Rep 2,592
well, your imagines didnt come thru above. Try imgur.
And martial said what in his reply?
03-31-2018, 12:15 PM | #14 | |
573
Rep 870
Drives: 2009 335i E90
The ebay seller is very likely just telling you whatever he thinks will get you off his back. Flash failing on multiple devices with "failed to write ecu. Unable to erase memory" certainly doesn't sound like an MHD problem, right?
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
03-31-2018, 01:08 PM | #15 | |
648
Rep 2,015
last flashed file...?
335i e92 TPC 19Ts
03-31-2018, 07:52 PM | #16 |
521
Rep 1,484
i believe only the late model e90 e92 n55 dmes were locked from the factory.
at this point i would contact mhd and see if they have any ideas. seems like your cable works and you have a battery charger. if the batteries in healthy condition. no reason you should get a write error.
04-01-2018, 06:12 PM | #21 |
489
Rep 483
Drives: 2009 E93 M3 DCT
Car battery voltage to low at 11.84 volts?
04-01-2018, 08:09 PM | #22 |
Rep 27
That wasn't during tuning, my charger holds a steady 13.7v when connected. That was after I did some things with ncsexpert to get rid of my tpms light and after the charger came off, I noticed the post above and then decided to check and see.
