Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > GFB DV+ installation
      03-28-2018, 11:04 PM   #1
Supermoon
Supermoon's Avatar
South Korea
166
Drives: 2011 e92 335xi
Has anyone tried accessing the diverter valve from the top by removing the inlet and turbo side charge pipe?
I really wanna avoid going from the bottom because I have an XI (requires dropping front subframe).
What would be the best way to take out the diverter valve on an XI?
Also, are there any known downsides of doing this mod on a stock turbo?
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD
      03-29-2018, 04:28 AM   #2
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
"Also, are there any known downsides of doing this mod on a stock turbo?"
I installed it in an almost stock turbo. Just has a more aggressive compressor wheel like the stage 1s. Sport spring included.
Haven't noticed any negative effects at all.
Supermoon166.00
      03-29-2018, 08:05 AM   #3
OTN55
39
Drives: Fbo e92 n55 335i dct
i did not try this. in the end i removed the water pump it was a bitch but worth it
      08-07-2018, 10:14 PM   #4
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
Does it sound any different at all? or feel different holding boost
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
      08-08-2018, 07:49 AM   #5
fatty335
fatty335's Avatar
123
Drives: e90 335i
Yes - it is entirely possible to install the GFB DV+ from the top - I did it. Removing the turbo inlet will allow removal of the top two of three allen-head bolts. I had to get creative and eventually used a standard hex key with a very small box-end wrench on it. The bottom one will require unbolting but not removing or draining the water pump (three bolts). You can then go in with a long extension from the front to remove the last bolt. No downsides on my stock turbo - just the opposite. Holds boost better and is more responsive than factory valve. I installed with the spring. No difference in sound. Hope this helps!
Supermoon166.00
      08-08-2018, 10:45 AM   #6
Supermoon
Supermoon's Avatar
South Korea
166
It's nice to know it can be done without draining coolant. Thanks.
      08-08-2018, 12:34 PM   #7
fatty335
fatty335's Avatar
123
Drives: e90 335i
FYI - you will need to remove the radiator fan also (not hard at all).
Supermoon166.00
