BMW M5 F90 (2018+) General Forums Cosmetic Modifications    IND | F90 M5 Painted Rear Reflector | Installation Procedure
      03-27-2018, 05:40 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
Drives: G80 M3 / G82 M4
Step 1: Remove the two 8mm bolts securing the plastic underbody panel to gain access to the rear reflector area.
Step 2: Pull the underbody panel aside and reach up behind the rear reflector. Squeeze the reflector tabs one by one and push them outward to release them from the bumper.
Step 3: With all three tabs released, you should be able to remove it from the bumper.
Step 4: With uniform pressure, insert the IND F90 M5 painted rear reflector into the factory location.
Step 5: Insert the two factory 8mm bolts by hand then tighten.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
      06-28-2018, 06:15 PM   #2
neohh
168
Drives: F90 M5
Having difficulty on step 2, the tabs won’t release. Any tips?
Search this Thread:
Advanced Search
