Getting a factory-fresh N55 installed. Is there anything I should upgrade or refresh?
03-26-2018, 11:04 AM | #1 |
BMW Portland
224
Rep 524
Some of you may have seen my previous posts in which I received the unfortunate news that I spun a rod bearing and need a new motor.
Well, after going over all of my options i'm deciding to keep the car and throw a brand new N55 in it. The car has 82k miles on it and I plan on keeping it for a while now that im getting a new motor. In this case, is there anything I should upgrade or replace while the front end of the car is apart? I was potentially thinking 335is motor mounts, but I can't really come up with anything else. The car will remain FBO on the stock turbo and MHD stage 2+, so no need for any more power mods. Thoughts?
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
03-26-2018, 12:34 PM | #3 | |
324
Rep 2,014
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
03-26-2018, 01:05 PM | #4 |
BMW Portland
224
Rep 524
Yes, I work for BMW Portland so I am having the job done at my dealership.
03-26-2018, 01:08 PM | #5 |
BMW Portland
224
Rep 524
Bought it used with 70k miles. Only 2 previous owners and I know the entire history of the car under the owner before me. The car had a JB4 and a charge pipe when I bought it, other than that it was stock.
Johnny Boost323.50 |
03-27-2018, 01:39 AM | #6 |
99
Rep 840
03-27-2018, 07:33 AM | #8 |
BMW Portland
224
Rep 524
Originally an Arizona car. 5 years over there, then 3 over in the PNW.
03-27-2018, 10:16 AM | #9 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Do you have the separate oil cooler? If not, I would trash the old one and install one. If you do have one make sure it is cleaned out VERY well. When your rod bearing went there was metal particles in the oil and they like to collect in the oil cooler. I have seen many replaced engines go bad again (not N55) in short order because of this. Personally I always replace the cooler and flush the lines well. It is cheap insurance when you figure in the cost of another engine.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
03-27-2018, 11:09 AM | #12 | |
99
Rep 840
03-27-2018, 12:02 PM | #13 |
1161
Rep 3,189
03-27-2018, 12:17 PM | #14 |
BMW Portland
224
Rep 524
As much as I would like to, there is a core charge for the new motor so I will not be able to. Also, given the symptoms, its pretty plainly obvious that the rod bearing was the cause of the problem.
03-28-2018, 01:18 PM | #15 |
245
Rep 1,595
Rod bearing wasn't the cause, it was just the failure point. Detonation or oil starvation were likely the problem. At a minimum I would take a look at the cylinder of the bearing that went bad to see if you had detonation. That might be from a bad injector which could trash your new engine too if you are reusing them. I would feel a whole lot safer knowing the cause if I was in your shoes.
03-28-2018, 02:30 PM | #16 | |
BMW Portland
224
Rep 524
