Anyone replace Valvetronic motor and seal on 2006 N52 specifically?
03-24-2018, 10:02 PM | #1 |
42
Rep 551
Thanks in advance.
On the US spec 330 (with magnesium valve cover) the VVT gasket is slightly different, and is not as robust. It essentially sits in place and as the N52 proper in this config. wasn't around long, there aren't many resources I can find on it. I'm having trouble making sure it's seated correctly as there are not screws, a lip, and the vertical strip to identify placement like on later N52s. Anyone have a 2006 330 or 325 and done this replacement with any tips? All Bentley manual, pelican parts, or YouTube have been the later (likely better part). I've installed everything and car running fine, but have seen some oil seeping. Leading me to believe I seated it wrong. Although there are no gaps, etc. Background- Over the past two weeks I've been doing the following: Valve cover gasket, VVT motor gasket, and related seals Oil filter gasket DISA valve (story for another day) Oil separator and various LEGO quality plastic tubing related. All is well except for the above, and of course an ignition coil failed on me right after it all got buttoned up Any help is welcome. Realize there are a ton of resources for the N52(b series I believe, post 2006) but I'm striking out. I can post a pic of part if helpful.
2006 Sonora Metallic 330xi.
DIY: Charcoal Delete, K |
03-26-2018, 11:44 AM | #2 |
douchebaggo
186
Rep 972
Here are a few things I remembered about the VVT motor gasket.
1. There is a lip, the high side facing out. 2. I installed it AFTER the VC was in place. 3. It does pop in place with some resistance. It will sit flush on top of the metal piece where you screw in the VVT motor. 4. I couldn't see any difference in terms of top-bottom orientation but I installed the new one the same way as the original. 5. Tighten the two VVT motor bolts onto the gasket side first before tightening the bottom bolt. |
Nebraska330xi41.50 |
03-26-2018, 12:13 PM | #3 | |
Grandmaster
768
Rep 798
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
03-26-2018, 12:38 PM | #4 | |
42
Rep 551
https://m.eeuroparts.com/Parts/16627...UaAjVHEALw_wcB They probably realized it was a cheap design and added the lip
03-26-2018, 12:39 PM | #5 | |
42
Rep 551
03-26-2018, 12:43 PM | #6 |
Grandmaster
768
Rep 798
Ah, I didn't realize that the old gaskets were different, sorry.
03-29-2018, 01:52 PM | #7 |
23
Rep 128
Hmm, I had the same problem. Took it apart, cleaned it, and put it back together. I need to check it again...
-Anthony Magagnoli
Pirelli World Chalenge: Rooster Hall Racing/FCP Euro #80 M235iR - 2017 Rookie of the Year NASA ST2 5.2 Motorsports Shelby GT350 #941 '08 "130i GT" 6MT / '01 Z3 3.0i Coupe 5MT / SpecE30 Drive Faster Now |
03-29-2018, 02:01 PM | #8 |
42
Rep 551
Let me know if you had success. My biggest thing was that the gasket didn't really "click" or seal it just kinda set in there and any more pressure on my end would push it through into the VC. I cleaned it yesterday really well and we will see. Hoping it just needed to seat in there and won't continue to leak.
03-29-2018, 04:20 PM | #9 |
douchebaggo
186
Rep 972
This statement had me thinking you either have incorrect parts or the installation wasn't right. The gasket should sit flat against the metal piece in the pic below. Pressure on the gasket will just press it against this metal piece. There is no chance for it to fall into the VC.
03-29-2018, 10:14 PM | #10 |
1007
Rep 2,108
I had done this years back, don't remember details. Here is a picture from Pelican Parts showing gasket in place on magnesium cover:
https://www.pelicanparts.com/BMW/tec...arge/pic09.jpg |
03-29-2018, 11:04 PM | #11 | |
42
Rep 551
03-29-2018, 11:06 PM | #12 | |
42
Rep 551
https://m.eeuroparts.com/Parts/16627...UaAjVHEALw_wcB Verified by Tincher and my local dealer based on VIN.
03-30-2018, 01:30 AM | #13 | |
1007
Rep 2,108
http://www.realoem.com/bmw/enUS/part...302&series=E90 |
