BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    DME Flashing/Tuning Bosch MDG1
      03-24-2018, 08:54 PM   #1
cookiesowns
cookiesowns's Avatar
587
Drives: X5 45e, 535i N54, X3 N55
Hi guys, while I don't own the new F090 M5 I do have access to latest PSDZ data from BMW and parsing the XML's show that the car uses the new Bosch MDG1 base DME's which has the onboard encryption. Looks like we're going to be stuck at the stock power levels for sometime.
And because bmw locks ZCP ( comp pack ) power flashes with FSC code that won't be possible.
Code:
<br>$DIF_VARIANTE: DME8.8T.0-S63T4-B44-F90-8HP-ECE-VS1---_Fzg_____________________________________</br>
        <br>$DIF_Entwickler_Kommentar: H4C99274B___________#H4C99274B_S63T4_F090_ECE_VS1_Fzg021</br>
Code:
<TOOL>SWE created by SWE-Generator 3.8.0 with config-file C:\work\171107\S63T4\data\SWE-Generator_MDG1_DS_P.cfg
</TOOL>
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
      03-24-2018, 09:09 PM   #2
onfireX5
3619
Drives: F90M5,F85X5M
RaceChip is coming....an easy 50hp.
      03-25-2018, 05:36 PM   #3
Tonymiabmw
Tonymiabmw's Avatar
552
Drives: Nardo F90 M5 on order
Code:
Code:
</TOOL>
Can still run a piggyback yeah?
      03-26-2018, 10:06 PM   #4
DallasLife345M
Drives: Uber
      03-26-2018, 10:31 PM   #5
cookiesowns
587
ewwwwwwwwwwwwwwwwwwwwwwwwwwwww
The only piggy back I'd trust is Dinan, or AA.
There's plenty of S63 motors blown due to piggy back. Piggy back naturally causes motor to run lean, and then run rich. It needs to fight the DME to maintain control.
      03-26-2018, 10:32 PM   #6
Tonymiabmw
Tonymiabmw's Avatar
552
I've always had luck with Burger JB4
Appreciate 2
      04-03-2018, 01:39 AM   #7
Sheharyar_rr
237
Drives: 14' 335xi M-Sport
I'm sure existing piggy backs will most probably work. For the M550i apparently the 2013's stage 1 was fully compatible with my car
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP
Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile
Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile
      04-03-2018, 10:05 AM   #8
onfireX5
3619
I have a Dinan on one car and RC on another. Curious where you have read about multiple s63Tu engine failures with stage 1 piggybacks ??????
      04-03-2018, 01:44 PM   #9
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
+1, plenty of tuned cars w/blown engines but have not heard of any piggys causing blown engines. I've owned two F10 M5's (still own a 15') and have run piggys on both from Day 1 w/ zero issues.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      04-05-2018, 12:58 AM   #10
cookiesowns
587
There are plenty of cars running piggys that has issues. Many has cracked ringlands or other variety of issues.
The only piggy that I'd trust is the Dinan as it's way more conservative and does not target a flat boost curve.
      04-05-2018, 06:56 AM   #11
josec70
josec70's Avatar
Issues maybe, blown engines? Many issues are with Dinan piggys btw; do a search on the F10 M5 forum.
Been running piggys for the last 6 years on two separate F10 M5's with zero issues.
      04-05-2018, 09:09 AM   #12
onfireX5
3619
Where are the forum posts of these failures ?
      04-06-2018, 08:26 AM   #13
TrevorM3
3322
Drives: 6.3 AMG
lol. i personally know at least 5 people who have blown a motor with a flash.
I ran the AA piggy for 6k miles and never one issue.
onfireX53618.50
      04-06-2018, 08:56 AM   #14
onfireX5
3619
I’ve looked around. Still can’t find stage 1 piggy blown engines. Now reflashes....,......boom....
      04-06-2018, 09:14 PM   #15
///M ARMY
1003
Drives: F90
Jb4
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      05-13-2018, 05:52 PM   #16
_carrera_
Drives: M4
Code:
Code:
</TOOL>
Its already broken,available for flash via obd
      06-01-2018, 01:22 PM   #17
esquire
esquire's Avatar
Drives: 2011 Dakar Yellow M3, 2018 M5
onfireX5 - If i remember right, your active on the jb4 boards right? Any update on their timeline to come out with their piggy back unit on the m5?
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip]
[Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE]
      06-01-2018, 06:25 PM   #18
onfireX5
3619
I don’t have any inside info. Terry had his M5 running 25psi (stock 20.5). He now has a few beta units out being tested. A pure guess would be 4 to 6 weeks.
esquire477.50
      06-02-2018, 03:42 PM   #19
Dethsupp0rt
329
Drives: N/A
Terry's car is still in the shop with xDrive issues, so it might be a little while.
      06-02-2018, 04:44 PM   #20
M5stallion
Italy
Drives: Bmw M5
24-25psi is a lot for a stock motor....
      06-02-2018, 04:45 PM   #21
onfireX5
3619
It’s concerning that he had a problem on a 2wd dyno with the M5 shifting into 4wd. Might not be able to dyno these in 2wd.
      06-02-2018, 06:19 PM   #22
onfireX5
3619
Why ? Mine stock is almost 21psi. + 3 - 4 isn’t crazy. IAT stayed under 115F.
