BMW M5 F90 (2018+) General Forums F90 M5 General Forum    1st dyno on our stock F90 m5
      03-22-2018, 07:56 PM   #1
DINMANN
DINMANN's Avatar
Drives: bmw f80m3 2015
BIMMERPOST
     Featured on BIMMERPOST.com
First dyno for our 2018 BMW F90 M5
We chose an unbiased company to the BMW community specializing in all wheel drive vehicles.
EVASIVE Motorsports in Santa Fe Springs Ca, uses the “Heartbreak” Mustang dyno which reads “real load” conditions as we figure the more popular Dynojet will be posted and want to give the enthusiast the most realist “upfront” information just like our Carbon Fiber products.
We did 6 pulls 3 with AWD and 3 with RWD, we will post dyno jets at later.
450 RWHP/481 RWTQ
471 AWHP/509 AWTQ
Also known as the HEARTBREAK DYNO 10-12% lower number than Dynojet.
Mustang Dynamometer is the most accurate and reliable dyno because it provides real-world loading and precise control.
Now for bragging rights Dynojet is THE MOST POPULAR DYNO IN THE US. This is why we stared with Mustang. I’m sure a Dynojet run will be up soon but for now we try to have this up for u all to see.
Eventually we will run on a Dynojet as well with higher number and for the cherry on top, Dynojet is still lower numbers than the flywheel 15-18%
they had 2 air fans on the front of the car, and it was cold and raining outside. I hope next week we can also do the dynojet as well.
after that, we have to get back to work and have full aero for this car.
the plan is to have it ready for bimmerfest may 26th 27th here in LA.
please dm me if any one needs any more info.
thank you cannan
More videos coming soon.
Appreciate 2
Brake_Late1937.50
Mcc420475.00
      03-22-2018, 08:20 PM   #2
ilushka85
33
Drives: 2015 i8
Was first service performed on vehicle ?
      03-22-2018, 08:25 PM   #3
M4LAKA
114
Drives: 2022 M5 Comp
I remember I drive the 1500km in a weekend on my m4 to get my first service right away lol
Currently:
2022 M4 Comp xDrive
2022 M5 Comp
Past:
2019 M5 Comp
2015 M4
      03-22-2018, 08:48 PM   #4
Quickburn7
956
Drives: 2018 Bmw M5
Seems pretty low when the E63s is making 575 to 585 HP at the wheels
      03-22-2018, 08:53 PM   #5
vtknight
vtknight's Avatar
967
Drives: 2019 F90 M5 Competition
close up video's are in the work, well post more later, this is just from my phone.
Great info! Normally the "heartbreaker" is a Dyno Dynamics dyno - but Mustang dyno's do read about 6-8%ish lower than Dynojets on average in my experience. Of course all of this can be configured to read whatever you want. Do you know the correction factor used?
That said - for a Mustang dyno - these are fairly strong numbers. I will guess these cars are around 540-550ish whp on the Mustang dyno and 575-600 WHP on the Dynojet for the MPH they are producing.
Subscribed!
Appreciate 2
      03-22-2018, 08:56 PM   #6
Demon Barber
292
Drives: 2018 M5, 2022 911 Turbo S
Mustang Dyno vs. dynojet vs crank is all very misleading, not to mention equipment variation. We need standardized numbers and testing amongst competitors for meaningful comparison. Having said that, all that matters is actual performance.
Appreciate 2
      03-22-2018, 08:58 PM   #7
ilushka85
33
Drives: 2015 i8
Unless first service was performed on the f90 full power is not unlocked on the engine. It is different from previous generations in this regard and even tells you about it till its performed right on idrive and cluster.
Additionally if you inspect the coding you will see that initial speed cap is 155 for first 10 hours of engine operation.
If you have m drivers package like on my car, the coding then changes top speed to 205 despite bmw saying its 190.
Long and short of it is this dyno is not relevant unless first service was completed on the vehicle.
Appreciate 3
      03-22-2018, 10:04 PM   #8
TheRealOrosie
BMW Fan Boy
TheRealOrosie's Avatar
Drives: //M
Where does it tell you this???
      03-22-2018, 10:06 PM   #9
vtknight
vtknight's Avatar
967
I cannot say this is or isn't so - I'm sure BMW could do it. I can say GM said the same thing about the Corvette C7Z (which even had the different Tach colours - to encourage lower shift rpm -before the break in point) - but it was found that the power was not in fact limited.
It will be interesting to see if it is true and how limited it actually is. The fact a "low reading" Mustang dyno showed a 509 whp result - with AWD drivetrain loss of 15% is 598 HP. That is without the likely low read of 6-8% which could place actual WHP at 549.47 and crank HP in the 646 HP range. If that is "before break in" numbers - I am even happier with my purchase lol.
EDIT: I just noticed I read the dyno sheet wrong - and likely because I would expect the WHP to be higher than the WTQ as the crank stock numbers are 600/553. At 471 - that is in fact low. Maybe there is something to the break in limited tune.
      03-22-2018, 10:11 PM   #10
ilushka85
33
Drives: 2015 i8
Which part ? It’s all in the coding. As far as car telling you it hasn’t been serviced and in break in stage it’s the yellow icon of car on dash and under vehicle messages as a yellow warning message.
      03-22-2018, 10:12 PM   #11
ilushka85
33
Drives: 2015 i8
I can tell you from what I’ve seen in the coding it is for sure there. How much it limits power by I don’t know. But it is limited.
      03-22-2018, 10:17 PM   #12
TheRealOrosie
BMW Fan Boy
Drives: //M
I can tell you from what IÂ’ve seen in the coding it is for sure there. How much it limits power by I donÂ’t know. But it is limited.
What coding? You are not being specific.
      03-22-2018, 10:31 PM   #13
onfireX5
3619
Drives: F90M5,F85X5M
470rwhp is a tad lower than I expected on a Mustang Dyno.
      03-22-2018, 10:35 PM   #14
ilushka85
33
Drives: 2015 i8
What do you mean by what coding ? You want me to send you the cfd files off my car ?
      03-22-2018, 10:42 PM   #15
KEMAHK
Drives: 911 GTS / M5 F90 on order
Heartbreaker dyno aside - a 470 WHP car does not produce a 10 sec 1/4 mile stock so something is off here.
Appreciate 5
m3less130.00
raysspl991.50
JMD637.00
      03-22-2018, 10:42 PM   #16
TheRealOrosie
BMW Fan Boy
Drives: //M
I mean how can you look at the "coding" and tell that BMW is limiting the car during break-in?
How do you know by looking at the "coding", as you keep stating?
      03-22-2018, 10:45 PM   #17
vtknight
vtknight's Avatar
967
As I said - I just noticed this as well. My brain expecting a higher WHP to WTQ number read them that way (as the crank number are apparently 600/553).
The fact the WTQ number are higher than WHP - and the fact they are quite low - makes me think there is something to the limiting tune. Each run has WTQ higher than WHP.
That said - the 509 WTQ is a nice number for crank torque - especially being a "low" reading Mustang dyno.
      03-22-2018, 10:51 PM   #18
ilushka85
33
Drives: 2015 i8
1. Because there is a speed limit till 10 hours of running time
2. The car stores a specific set of flags for first service and engineers went thru enough programming to specifically track and identify this for idrive etc.
These types of efforts would not make sense if more things were not limited / detuned besides just top speed and 10 hour engine running time
      03-22-2018, 10:55 PM   #19
vtknight
vtknight's Avatar
967
Exactly. As stated - something is off just for the fact WHP is reading lower than WTQ. Trap speeds of 127-129 MPH are not coming from a 470ish WHP car at 4300+ lbs.
      03-22-2018, 10:59 PM   #20
MTHX
MTHX's Avatar
233
Drives: 335XI MPerformance edition
2018 F90M5  [0.00]
20% drivetrain lost on awd and 15% on rwd normally ?
on mustand dyno, could be up to 30% on awd.
if you want to compare number with e63s 2018 on mustand dyno ...
https://grfilms.net/v-i-dyno%E2%80%9...n_h3Jn8z0.html
E60 550 2007 - Grey //
F30 2015 335XI MPerformance edition - Lacuna Seca Blue //
F30 2015 335XI MPerformance edition - Grey black //
F90 2018 M5 - Donington Grey
drmdvl56.50
      03-22-2018, 11:01 PM   #21
TheRealOrosie
BMW Fan Boy
Drives: //M
Exactly. You need closer to 700 crank to pull those numbers.
      03-22-2018, 11:03 PM   #22
vtknight
vtknight's Avatar
967
Newer cars - 15% AWD, 10-12% RWD.
