ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      06-06-2008, 03:48 PM   #1
AREN101
Drives: bmw 3.0 Z4
break pad install question
hello all,
i recently installed new break pads on my zed, old one were really worn and the break pad warning lights on the dash was on. Bought axxis ultimate break pads for all four wheels and new break pad sensor. total cost me only $122.00.Install was easy on scale of 1 - 10 with 10 being hardest i'd say this project was a 4. Okay install looks good but the light on the dash is still on - does anyone know how to reset this break pads lights.
thanks.
      06-06-2008, 04:23 PM   #2
Spaceman Spiff
86
Drives: R8, 996 C2, Z4MR (sold)
I am not sure if you must reset the light?! I installed new pads and rotors last week and the light went off automatically. Did you install both sensors correctly?
      06-07-2008, 12:18 AM   #3
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
The sensors are activated by a small wire that breaks an electrical connection on either the front left or rear right set (or both) when the pads wear. You will need to replace the sensor(s). They are not very expensive.
You have to be 100% behind someone before you can stab them in the back.
David Brent
      06-09-2008, 12:56 AM   #4
AREN101
Drives: bmw 3.0 Z4
thanks guys
thankfully after 2 days the lights miraculously disappeared
      06-17-2008, 01:11 PM   #5
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
That, or set the ignition to the ON position. Do not start the car.
Wait 45 seconds, the system will reset the brake sensors.
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      06-18-2008, 01:28 AM   #6
AREN101
Drives: bmw 3.0 Z4
Smile
thanks
      06-18-2008, 09:10 PM   #7
Graham M
I love my Z. Pure sex on wheels.
Graham M's Avatar
48
Drives: Is sold, goodbye everyone!
Its brake, not "break" (just so you know)
      06-21-2008, 06:06 PM   #8
Jeffrimerman
Drives: BMW R50
A guy at the parts departement told me I can re-use the brake sensor if it isnt damaged, but logic tells me if it is making contact with the rotor it is probably damaged. Is this true? I need one for each side right?
      06-22-2008, 12:07 AM   #9
jmillet
jmillet's Avatar
63
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Driver front, pass rear
Brake sensors are located on driver front and passenger rear.
If your dash brake wear warning light is on then you need a new sensor.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-21-2008, 08:12 AM   #10
Shooter
Drives: Z4 2.5i 2003
Hi there !
After nearly three months of use, are you satisfied with the Axxis pads ?
I'm still hesitating between Axxis Deluxe and Hawk HPS (or sticking with OEM...).
      09-05-2008, 03:04 PM   #11
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
Originally Posted by Shooter View Post
Hi there !
Hawk HPS will give you better brake feel than the OEM pads and offer less brake dust.
I personally went with Hawk Ceramics in the rear with OEM rotors.
In regards to the brake sensors, yes there are two, but if you would like to eliminate them as you have no need for them, simply cut the wire, you will find two wires inside the protective sleeve, splice the two wires together and wrap it up with electric tape. Then zip tie the bundle of wire out of the way of any moving parts. Voila, sensors disabled.
But if you are going to disable your sensors, please make it a habit to inspect your pads when you do your oil changes or just give them a quick glance every now and then.
2006 VW Jetta 2.5
Once upon a time...
      10-07-2008, 09:48 AM   #12
AREN101
Drives: bmw 3.0 Z4
very much liking the Axxis brake pads, i have significantly less brake dusts - so less cleaning of wheels.
      10-07-2008, 02:34 PM   #13
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
For a dual-use setup, I personally would suggest the Fedoro 2500s front and Axxis ULTs rear. Also make sure you're bedding-in your pads after changing them.
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
zpost
