06-05-2008, 06:33 PM | #1 |
salivator
38
Rep 539
Supersprint X-pipe
I have been considering getting the Supersprint X-pipe without the resonators and connecting it to the other OEM sections.
1-do you guys think that the fitment will work without sawing anything? 2-how do you think this will affect overall sound? 3-what is the difference between the black steel and the stainless steel listed on their site? 4-Is there any reason that this is a bad idea? http://www.supersprintna.com/product...earch_model/86 |
06-09-2008, 01:46 PM | #3 | |
BimmerPost Supporting Vendor
2868
Rep 11,374
1- You will need to cut the stock pipes unless you purchase the full header back SS exhaust system. 2-The sound is amazing when removing the Secondary cats and resonators. It might be too loud for some. 3- No clue. Send SS an email 4- If you’re ok with a loud car then go for it. I also heard that SS make a resonated X-pipe for Hamann. That might be better for daily driving.
06-12-2008, 01:56 AM | #4 | |
48
Rep 1,436
Drives: E70 X5 M
2 - If you're replacing just the x-pipe section & nothing else then it'll obviously sound louder but not sure how much louder. Might as well save up a little longer & get an aftermarket axle-back while you're at it but that's just me. 3 - Not sure either 4 - It'll be louder if you like that The one you linked originally was just the U.S. distributor's (BMP Design) website. There are much more info/products on SS's direct website: http://www.supersprint.com/a_prodott...ello=bmwE92m31
'13 E70 S63B44A
'17 95B GTS |
06-12-2008, 12:18 PM | #5 | |
salivator
38
Rep 539
european car mag is publishing a flow test of all of the sections of the e92 M3's exhaust. This should show where the most restrictive sections are. |
06-12-2008, 04:54 PM | #6 |
48
Rep 1,436
Drives: E70 X5 M
Is this the current issue on newsstand? If yes then I'm going to Barnes & Nobles later today.
'13 E70 S63B44A
'17 95B GTS |
06-12-2008, 08:08 PM | #7 |
21
Rep 362
06-12-2008, 08:29 PM | #8 |
48
Rep 1,436
Drives: E70 X5 M
Thx for the info. I'll go later tonight.
'13 E70 S63B44A
'17 95B GTS |
06-13-2008, 03:27 PM | #9 |
salivator
38
Rep 539
i have the July issue, which is the first in the 3 part series. I have yet to recieve the 2/3 issue.
Let me know what you guys think about the article. THey say that they put the "flow testers" in 4 places...primary cats, secondary cats, resonator, and muffler. The article goes on to say something about the restriction in the first position meaning that the M3 is a good candidate for headers....How do they know the restriction is in the headers and not the primary cats? am i missing something? please share your thoughts... |
11-24-2010, 02:41 PM | #10 |
12
Rep 117
Has anyone else done this or experimented with just swapping out x-pipes and/or resonator sections?
I would like slightly louder than stock but not too loud and would prefer to not drop $3,000 just to get a little more volume and flow, but not a full race sound. On my Cayenne Turbo I did a Fabspeed secondary cat bypass pipe for like $500 and it sounds simply amazing. Just slightly louder than stock at idle, maybe 20% louder but about 50% lounder at WOT and it sounds nasty as hell. In mid range rpms it is just a bit throatier but not much louder. |
11-27-2010, 05:52 AM | #11 |
11
Rep 365
Drives: M3 E92 AW
Get the full exhaust system. You wont be dissapointed....
I did and i love it. I have a non resonated X pipe, it´s a bit loud, but i love the engine sound. Here you have my thread about this if you want to take a look. http://www.m3post.com/forums/showthread.php?t=234155 Best Regards, Maika
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com |
05-06-2011, 05:14 PM | #12 |
922
Rep 15,818
Since I don't like starting too many new threads... I'll bump this one with my question:
What do you guys think of the Supersprint Xpipe in comparison to the Challenge Sport or Gintani with HFC+resonators? I do not want to go catless... the smell is unbearable for me. I don't know if I want to do a full system yet... I want the increased power, a little increased sound, and no no no drone. I'm not the type that likes the exhaust that can be heard from miles ahead. I'm fine with down the street So I was looking at this: http://www.supersprintna.com/product...earch_model/87 and combing it with their cats. My other question is... are they seriously expected to get $4k for their HFC Xpipe with resonators? That's crazy.... Anyways...one main reason I'm considering it is that I may be able to get a slightly used one for a really good price... Thanks for your input
05-06-2011, 07:19 PM | #13 | |
Rep 101
05-06-2011, 10:59 PM | #14 | |
471
Rep 2,991
This won't work. The X pipe is designed to connect directly to the connecting pipes used with either the Sport mufflers or the Street muffler. If you don't want to use the X pipe, you use the short connecting pipes in addition to the ones that come with the mufflers, to connect to the stock X pipe. You'd have to cut the stock X pipe and the stock mufflers and try to figure out some way to connect the stock connecting pipes to the SS x pipe. I doubt this will work without some welding, given that the stock connecting pipes are hydro formed and not round. |
05-07-2011, 01:42 AM | #15 |
1390
Rep 2,336
try Active Autowerke mid pipe. takes 10mins to put on. might even have a used set for you. http://store.activeautowerke.com/act...w-cats-p2.aspx
05-09-2011, 01:36 PM | #16 | |
922
Rep 15,818
Cause the seller seems to want about 1800 for it...
05-09-2011, 02:53 PM | #17 |
Rep 101
05-09-2011, 05:02 PM | #18 |
922
Rep 15,818
well the one he has has the HFCs with it
