The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > RAM Air Scoops - what speed needed
      03-15-2018, 09:22 AM   #1
N52UNED
N52UNED's Avatar
Drives: '07 328i/330BPC
Yup ... another Ram Air Scoops thread. I've read through all the threads that contain the subject, but there's really no thread that give any definite answer. Too many threads are ... "it does nothing" / "it's nothing but a bug catcher" OR "it works" / "it works but ... "
I'm in the camp that ... it does work. However I understand that in order for it to give any actual performance gain ... a certain rate of speed must be met - or else the performance increase is negligible.
I'm not expecting a turbo or a Ram Air hemi effect ... but I'd imagine there's some butt dyno effect. With that ... what is the rate of speed one needs to achieve for the scoops to have any butt measurable effect?
(FYI ... I will be doing a K&N w/ Carbon Delete and Silicone Intake to complement the scoops. Also I do a fair amount of highway with speeds 75+ -- mostly in the 85 mph range. Plus my in town driving is 50-60 mph in many areas).
Thanks ... please don't let this become another Scoops bashing thread. Quite a few members have them and believe in them ... others, like myself, would like more info that's not spread over 30 threads to get concise information.
      03-15-2018, 09:42 AM   #2
TomD335xicoupe
319
Drives: 08 335XI me ,19 x3 M40 wife
I put them in , they are cheep and I can not think how it could hurt but I have no idea if they help either. Just something else to buy for the car, I like to buy it presents. I know this answer does not help but I am board, and nobody else is giving you anything so WTF I will put my half cent in, need the other 1.5 cents for parts.
Appreciate 3
      03-15-2018, 11:44 AM   #3
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
It's not a discrete cutoff point, it's a continuous function. It would also be dependent on wind direction and speed, altitude, and relative humidity. If they did anything. They probably don't, cars often have low pressure cells in that region, not high pressure cells. There's a high pressure cell on the fenders which is why the BMW PI has a sealed intake opening there.
Generally speaking, drag is more important than weight after 60 mph, and so that is probably the rough inflection point for this sort of thing.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      03-15-2018, 11:48 AM   #4
e92_bryan
Drives: ‘11 e92 328
Again...
No gains
And will probably “hurt” to some extent
I can only imagine all the crap that gets sucked into the intake now plus possible flooding in heavy rain?
      03-15-2018, 02:40 PM   #5
M.Etreby
Egypt
36
Drives: 2011 Black Sapphire E90 330i
120km/hr and above this is when you shall feel a little something. IMO it makes the engine breathe easier where the intake box is always rich with cold air, so its better instead of asking the engine to suck by itself, a draw back is that you will need to regularly clean up the box and filter more than the normal periods
M.Etreby
F M double Grills, 19"313, Perf.Exhaust with dimisatips, RPI red scoops, K&N filter, LUX-H8 160, Aluminum strut bar, PBX, Perf. Suspension, F30 M-Perf. Brakes
N52UNED179.00
      03-15-2018, 04:42 PM   #6
N52UNED
N52UNED's Avatar
Thanks for the input ... 75 mph is a bit higher than I was hoping, but it will work when traveling on the highways. I'd hoped it was closer to 60 mph so I could get a bit of gain around town.
The cleaning is a point of contention ... if I had a Euro box or AFe Stage 2 then I'd be a bit more apt to do it, since popping a top is a lot quicker and easier than having to take out the whole box every so often.
      03-15-2018, 05:27 PM   #7
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
It seems that I say this often but I think it needs said again on this thread.
Try logging your changes. It's easy and cheep. Support your statements with actual data logs.
A stock N52 will draw something like 700kg of air per hour at full load and 6,800 RPM. Manifold pressure drop will be about 30 millibars.
Make a few runs develop a baseline and then start making changes and log after.
The best tool for us right now is TesTo and it's a Windows based program. Having laptop in the passenger seat is a pain but having real data in invaluable.
There is no way I could have learned as much as I have without logging. Not saying I am anything more than an amateur.
Appreciate 4
Phyrexia502.50
Taskmaster2465.00
N52UNED179.00
      03-15-2018, 09:16 PM   #8
CobraMarty
CobraMarty's Avatar
619
Drives: 2007 328xi e90 + e92
I'm a believer and have them on both 328s.
One into EURO intake stock elbow.
Other into -first- carbon delete, aFe dry filter, silicone elbow.
then -second into aFe Momentum PRO 5R and supplied filter and included larger aFe molded elbow.
The aFe PRO box has 2 vents about 1"x4" each in the front of the box and I think that they are 'venting' any ram/pressurized air and just let 'noise' out. I want to block these vents and test. Just my theory.
Ram effect 60, 70, 100 mph probably 0.1-0.15 psi. I don't have anything that sensitive to test with.
N52UNED179.00
      03-15-2018, 10:56 PM   #9
hassmaschine
Drives: "NBO" 330i
If its not possible to test it because the difference is so small - what makes you think it makes any difference at all?
Rjahl is being modest. The stock N52 hardware & sensors have sufficient resolution to measure any small changes. If you can't even measure a difference, its definitely nonsense.
Appreciate 4
Phyrexia502.50
Taskmaster2465.00
rjahl996.00
      03-15-2018, 11:26 PM   #10
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Originally Posted by e92_bryan View Post
Again...
No gains
That's an old wives tale. I've had these things on my E90 since the very beginning, my first mod actually. 65000 miles later, still going strong.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      03-16-2018, 07:50 AM   #11
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
I have a working copy of INPA, I may be able to give it a shot.
CraZy how it's taken this long to get any data...
      03-16-2018, 08:13 AM   #12
CobraMarty
CobraMarty's Avatar
619
Pressure gauge or transducer, not BMW hardware/software.
      03-16-2018, 08:31 AM   #13
hassmaschine
Drives: "NBO" 330i
I guess what I'm saying is, the engine already has the necessary sensors/hardware to measure any difference. It has a MAP sensor, it can datalog at a high-rate, etc. That was Rjahl's point as well.
      03-16-2018, 08:32 AM   #14
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
You know where I work.
Will only take a few minutes to set up.
Taskmaster2465.00
      03-16-2018, 08:52 AM   #15
N52UNED
N52UNED's Avatar
Absolutely agreed ... scoops have been around for quite some time now and all I read is theory to prove one's belief that it works or doesn't.
As rudimentary as this youtube video is ... it's the closest thing I've seen to the idea of scoops working; or perhaps more like proof they route more air to the air box. And this is based upon up to 25mph wind speeds ... not the amount of wind chill factor / forced air pressures one would get at highway speeds. (plus you get to hear a bit of classic Michael )
.... However it does not answer the question of percentage of increase ... if any relevant increase ... or decrease for that matter. I highly doubt you're going to get anywhere near a 10% gain. Heck a silicone intake has been purported to give a slight increase ... so why not scoops?
Plus for the price ... if they can aid you car in efficiency in any way, that might be something to think about.
      03-16-2018, 08:56 AM   #16
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
Anyone here fab up scoops themselves?
      03-16-2018, 05:54 PM   #17
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
While working on another problem, the math made me think about this conversation.
Here is some interesting "tid bits".
At 50 MPH the wind pressure on a flat wall is about 6.4 Lbs / ft^2.
That's 0.044 PSI or 0.003 Bar / 3 millibar.
Sorry, you are not going to feel that on a butt Dyno.
The front end of a car is designed to slip through the air and is anything but flat. The 6.4 Lb's /Ft^2 could be reduced by at least 50%.
Does anyone see any error in my math?
Appreciate 2
Phyrexia502.50
N52UNED179.00
      03-16-2018, 07:24 PM   #18
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
If the question is, "is there a difference?", even after you install/remove them to test, there is no difference.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
      03-16-2018, 07:26 PM   #19
Phyrexia
Resident Pedant
The math checks out.
      03-16-2018, 07:33 PM   #20
Phyrexia
Resident Pedant
Behold!
rjahl996.00
      03-17-2018, 08:22 AM   #21
CobraMarty
CobraMarty's Avatar
619
Why, they are only $50-$80
Posted chart support this.
+0.15psi (92mph) will add 1% increase in power, for us about +2HP for $50.
Phyrexia502.50
      03-17-2018, 10:29 AM   #22
hassmaschine
Drives: "NBO" 330i
yeah, 2hp at 92mph, sure - makes sense if you track the car all the time I guess. But otherwise, I hardly ever go that fast, so I would never see a difference. The N54 guys will claim you can't feel 10hp, but I know you definitely can't feel 1hp.
In the end it's a cheap mod and people have fun working on their cars - personally I just don't care about 2hp.
