BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Enhanced Bluetooth Coding
      03-14-2018, 08:55 AM   #1
csm7djs
68
Drives: G05 X5 3.0d M-Sport
Just getting prepared to code my new car (when it arrives) and I wanted to code enhanced bluetooth.
I didn't specify the EBT but know I can code it to unlock the SMS, office integraration.
Having done it many years ago on a 1 series I just Change FA from 6NH to 6NS and bingo.
Do I need to replace anything on my G30?
What VO code do I need to add?
Do I need to remove anything from the VO?
Is it 6NW or 6NS?
thanks
      03-14-2018, 09:51 AM   #2
sjak92
sjak92's Avatar
150
Drives: G05 30d MY24 + G20 M340i MY24
Change the following in HU_NBT all to Active
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
REMINDER_TRIGGERS_EIN_AUS
MACRO_PIM
      03-14-2018, 10:43 AM   #3
csm7djs
68
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
Is it just that simple? No VO changing like before?
      03-14-2018, 10:58 AM   #4
sjak92
sjak92's Avatar
150
Worked for me using BimmerCode
Appreciate 2
      03-14-2018, 11:04 AM   #5
csm7djs
68
thanks - i'll keep that in mind if I use the bimmercode route.
I was going to code using e-sys.
TBH whatever is easier works for me...
      03-28-2018, 02:20 AM   #6
csm7djs
68
Ok tried that list above. I now get the email option appear. But no Messages...
Also I found everything except: REMINDER_TRIGGERS_EIN_AUS
      03-29-2018, 02:44 PM   #7
sjak92
sjak92's Avatar
150
Un pair and then re pair phone. Make sure that notifications are turned on
      03-30-2018, 03:00 PM   #8
csm7djs
68
And I think that is where the problem lies. I don’t have the show notifications option on my iPhone. Tried the wife’s and she doesn’t have it either.
      04-04-2018, 03:56 AM   #9
csm7djs
68
After another attempt at coding ehanched bluetooth on a brand new G30, I can confirm it is possible with bimmercode.
There is a new option called something like MENU_OFFICE_SHOW and this this needs to be set for it to display the extra options.
      04-04-2018, 11:08 AM   #10
Shadders
United Kingdom
Drives: G30 M Sport
My g30 is on PCP, if I decide to unlock these features too, will BMW be able to detect that I’ve done it, and will it screw up the warranty or PCP terms??
Gone: 520d SE F10 in Blue
Current: 520d M Sport G30 in Alpine White
      04-14-2018, 05:54 PM   #11
Simpaty
16
Drives: Bmw 320d sedan F30
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
you are forgetting
OFFICE_MENU_ENABLE
      04-18-2018, 04:27 PM   #12
csm7djs
68
Originally Posted by Simpaty View Post
you are forgetting
OFFICE_MENU_ENABLE
YEP - that is the one I was on about - close sorry
      04-29-2018, 06:17 AM   #13
sanjuvarma
Drives: 2018 BMW 530e / 2017 BMW x1
BimmerCode gave issues.
Hi all,
I have now an issue that I want to solve myself if possible, with your help.
I've had this 2018 BMW 530e iPerformance since Nov 2017 and loving it. I had been using the VGate WiFi adapter and the BimmerCode app to change a few settings here and there. About a month ago I went in again, to change a couple of more settings and right after that, noticed that the car won't charge anymore, gave me a Charging Error message on my BMW app, I have a Juicebox L2 Charger box at home. Tried a few other chargers (110v) and my charging facility (ChargePoint) at work, everything gave the same error.
Took it to the dealer, they kept it for a few days, reset all codes and it's back to normal again. I assumed something I did on BimmerCode that may have upset something.
A month later, last night, I wanted to code a couple of things which I had done when I first leased the car. I thought it was ok to do that so I went in again, just changed the starting animation to M type, changed the warning sounds to bmw i type, that's all!! And got the same charging error!!!
I hate it that I may have to go to the dealer once again. Can anyone please help!!!!
Thanks
      04-30-2018, 02:30 AM   #14
csm7djs
68
Originally Posted by sanjuvarma View Post
Hi all,
Thanks
BimmerCode takes a backup when you first connect - have you tried reverting back to that?
      05-01-2018, 03:08 AM   #15
ta5mhu
Drives: 530e
Gonna give this a whirl on mine.. Fingers crossed!!!
      08-22-2018, 08:28 AM   #16
psu
Netherlands
Drives: G31 - BMW 5-serie 540i xDrive
Functionality
I myself have a G31 and interested in also coding with Bimmercode (already registered and used other options with success). My question is what does this bring? - ability to connect a second BT phone? Ability to read textmessages? more?
      08-23-2018, 03:49 AM   #17
csm7djs
68
yep, ability to read text messages and connecting a 2nd phone.
      08-26-2018, 02:44 AM   #18
psu
Netherlands
enhanced features..
it also enables ; phonebook pictures.. i expected that in coms section you could choose phone2, but cannot see this still.
      08-26-2018, 03:39 AM   #19
Itsme
Drives: G31 520d
Hi psu, I did this yesterday on my G31 (Jun build) and seem to have got it all working. In the expert mode list of parameters I found a setting that was something like BLUETOOTH_2ND_HFP which I set to aktiv, this has added the option of a second phone to the display.
      08-26-2018, 03:29 PM   #20
psu
Netherlands
'itsme' Thanks!, only changed the suggested ones as in beginning of post, will change this one as well , thanks! more options/parameters suggested in relation to enhanced bt?
30/08 add : worked flawlessly, 'itsme' thanks again..
      08-27-2018, 03:15 AM   #21
Itsme
Drives: G31 520d
I’m sure there are more that could be changed, but I have no experience myself and was reluctant to experiment too much just in case I messed something up! If anyone else changed other parameters for enhanced bluetooth, I’d be interested to know.
      09-02-2018, 02:06 AM   #22
psu
Netherlands
Are there possibilities to turn on 'screen -mirroring' as well? Or do I need to turn on wifi? , and how to do this? (Seems that apple Carplay, which i have connects to wifi, thus hardware wise must be possible)
5post
