DISA valve gasket damage?
03-12-2018, 08:58 PM | #1 |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
I purchased a used 3IM and noticed that the gasket on the small DISA valve (PN 11617560538) was damaged in two sections:
Here is how a new DISA valve looks for comparison: And where it goes: Is this valve still usable or should it be replaced? Other than the damage pictured above, the valves appear to be in good condition. Update: For posterity, I was able to repair the gasket using Krazy Glue and it installed fine. However, the valve's servo motor is faulty and it triggered code 2AAC. There was a significant amount of oil on and inside this valve so I suspect the oil damaged both the gasket and motor. Last edited by The Nightman; 04-27-2018 at 02:29 PM.. |
03-13-2018, 09:03 AM | #2 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Never seen damage on that side of the valve. Usually the internal seal breaks away. I can't comment if that is a deal breaker or not. When I pulled my 3IM apart my large DISA valve looked like this:
https://drive.google.com/file/d/0B8p...ew?usp=sharing |
03-31-2019, 03:48 AM | #4 |
480
Rep 1,600
They are a super snug fit. I had to really put some pressure on them to seat them. Next time i will probably use some rubber grease inside the manifold but i thought the film of oil inside would have been slick enough.
Even when i removed both my existing valves and both the valves out of the donor manifold, I had to use a prybar. I reckon the seal had bonded to the manifold and tore a bit on the way out. |
