Replacing/Upgrading Engine Mounts?
03-12-2018, 12:04 AM | #1 |
12
Rep 109
Alright, so it looks like my engine mounts are shot and need to be replaced. After searching the forums, it looks like the consensus is upgrading to the 335is mount on the passenger side (at least). However, realoem lists this part #22116793240 and you can't find that thing for under $600. That's outrageous, and there's no way I'm paying that for a single engine mount.
Any other recommendations? Have they changed part #s and those older ones are just harder to find or something? Charging 6 times the cost of a regular mount is just blowing my mind right now. Thanks in advance. |
03-12-2018, 12:23 AM | #3 | |
2465
Rep 9,004
03-12-2018, 10:37 AM | #4 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
I don't think you're looking hard enough, found it no problem on ECS tuning. I proactively did the swap when I had to do my oil pan gasket (my mechanic lifts the engine vs. dropping subframe).
03-12-2018, 11:05 AM | #5 | |
12
Rep 109
Which part is the upgraded one? |
03-12-2018, 11:21 AM | #6 |
Save the Manuals!
1227
Rep 1,239
Drives: E91 RWD 6MT, X3, Ducati S4R
Garage List 2011 E91 6MT RWD &q ... [0.00]
2005 Ducati S4R 996 [0.00] 2000 Ducati M750 [0.00] RIP - 2011 E91 328i ... [10.00] |
You might also want to consider the 034 Motorsports mounts. These are 50A durometer solid rubber without the dampening fluid These are slightly less compliant than the iS mounts and less harsh than a poly.
2011 6MT RWD ClubSport Wagon | 3,185lbs | 1 of 149 ZSPs delivered in North America
Outside: BMW M-Aero, Euro region lighting, Seibon | Inside: M3 cockpit, Recaro SPG, Prototipo, AutoSolutions SSK, UCP | Stop: M3 ST-40R, PFC | Grip: Solid-mounted subframes, rear coilover conversion, M3 Nitron R3, Hyperco, SPL, AKG, ARC8 | Go: StageFP, CF snorkel, 3IM, MILVs, SuperSprint headers, Dundon Motorsports Inconel exhaust, VoltPhreaks | Cool: CSF | PCA #2018100384 | BMW CCA #505794 |
03-12-2018, 11:30 AM | #7 |
Rep 29
the Rein part is identical to the BMW mount but it's been on backorder ( maybe they stopped making it?). Within the past few mounts the price shot up. Try pelican parts
https://www.pelicanparts.com/More_In...6-793-240-M203 Fcpeuro also has the BMW part for 235 |
03-12-2018, 11:33 AM | #9 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I have the 034 Motorsports mounts. Feel like stock but I know they are a bit stiffer. Given the price they seem like a good solution. I worry about the solid mounts and NVH.
03-12-2018, 07:20 PM | #10 | |
Save the Manuals!
1227
Rep 1,239
The 034 50A solid rubber mounts are in the sweet spot for a dual-use vehicle IMO. They have mildly more direct feedback than stock without NVH penalty nor concern for leaking. Other's mileage / taste may vary. The new owner of my Turner mounts loves them, together with solid AL trans bushings. Different strokes...
03-21-2018, 09:21 PM | #12 |
Guest
Rep n/a
Drives:
Thats hilarious, It might be a out of production thing I upgraded to the 335is mount long time ago on my N52 330i and I paid less then 100 for the genuine BMW mount.
Edit, if you see my post here http://www.e90post.com/forums/showthread.php?t=881816 You will see that I paid 78 bucks for the genuine 335is mount LOL. |
03-22-2018, 06:33 AM | #13 | |
355
Rep 1,192
I bought his Turner Mounts and they were perfect for my application. Also then later installed solid aluminum trans mounts. Thanks again, Scott! |
tetsuo1111227.00 |
03-22-2018, 07:31 AM | #14 |
Slow.
3782
Rep 7,151
How are the solid aluminum trans mounts?
03-22-2018, 04:33 PM | #17 |
97
Rep 414
Does anyone know if 034 ever addressed their motor mounts failing? I was completely set on buying the 034 to replace my 115K original engine mounts but then I came across this thread which makes me hesitate:
http://www.1addicts.com/forums/showp...&postcount=177 |
lab_rat394.50 |
03-24-2018, 12:16 PM | #19 |
Slow.
3782
Rep 7,151
03-25-2018, 02:53 AM | #20 |
355
Rep 1,192
03-26-2018, 12:30 PM | #21 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Just to add:
I replaced my motor and trans mounts with Corteco OEM and E46 M3 ones, respectively, and it made quite a difference in shift feel. My old mounts certainly weren't broken either, just worn after 110k miles. Keep this in mind when upgrading mounts. |
lab_rat394.50 |
12-27-2018, 08:36 PM | #22 | |
83
Rep 337
The Cortecos still feel strong? |
