Engine dies after 5 seconds
03-11-2018, 04:15 PM | #1 |
Rep 3
I replaced the valve cover gasket. On the initial start up it idled fine for about 10 minutes, as soon as tried to increase the rpm the engine started acting up and is sounded like a diesel so it shut the car off. Since then it will start for about 5 seconds and then die. I did get a P052b code and the noise it was making definitely sounds like a timing issue. I followed the procedure for the eccentric shaft actuator, so i don't think that's it.
When I was removing the valve cover, I forgot to disconnect the battery and during removal I accidentally hit the positive battery terminal with my wrench (could I have shorted something? The 40 amp fuse in the fuse panel is ok.) I've double checked my work and everything's connected properly. I'm about to take it to a mechanic but if seems like it should be a simple fix. Thanks |
03-11-2018, 09:42 PM | #2 | |
2465
Rep 9,004
03-13-2018, 10:42 AM | #3 |
185
Rep 1,017
If the wrench touched power and a ground, it's possible that modules through out the can be affected when grounding out a power source, there very sensitive to power. Thes cars with power and ground issues have a tendency to thro false codes. To rule out fuel pressure, use a gauge to make sure the rule pump module wasn't affected. There is a circuit board in there.
03-13-2018, 10:49 AM | #4 | |
996
Rep 2,287
03-18-2018, 05:56 PM | #5 |
1007
Rep 2,108
You can try to remove the Valvetronic motor and place it back, in case its worm gear had not seated on the eccentric shaft gear. There are some valve covers DIYs that tell to wiggle it out when removing the Valvetronic motor and wiggle it in when installing it back. But wiggling it out and in is not the correct way to do, correct way is listed here at PelicanParts article (and at Bentley manual):
https://www.pelicanparts.com/BMW/tec..._Replacing.htm Steps with Figure 11 to 15 are how to remove it correctly, and step with Figure 20 is to install it in. Basically to remove, you first turn the motor with an allen wrench from its rear clockwise until it hits the stop. Then with all the bolts removed from the motor holding it down, you turn counterclockwise as you are pulling the motor gently. Because of the worm gear at the end of the shaft of the motor, as you rotate its shaft with the allen wrench it will be pushed out naturally as the gear turns. Install is opposite, you place it as much as it can go. The start thread of the worm gear will engage with the start thread of the eccentric shaft side gear. You rotate with the allen wrench clockwise, which will pull the motor in all the way and seat it. Another thing to look at with the code you gave and the year of your is Vanos bolt recall: https://static.nhtsa.gov/odi/tsbs/20...45283-5967.pdf If you don't know try to see if your car had this recall done from a dealer. |
