DISA valve rebuild
03-10-2018, 07:54 PM | #1 |
80
Rep 199
DISA valve rebuild
I have a 3SI from an X3 that needs the big DISA valve to be rebuilt since the door is loose and moves by itself. I'll be buying the kit from here:
https://vanos-bmw.com/repair-kit-for...-n52-n52n-n52k unless you guys know of another source. As for my small valve, it is stuck in the open position and I can't move it with my fingers. Would that be enough of an indicator that the valve is still good? Attached is a picture of it: |
03-10-2018, 08:15 PM | #2 |
Apex Forged 19", AA headers, MILVs, 3IM, Euro Intake, Swift Spec-R
87
Rep 255
Drives: 2013 328i coupe
That's where I bought my repair kits. They'll combine shipping if you buy them both at the same time. The hardware looks like it's made of stainless steel and the fins are aluminum, everything seemed to be good quality, much better than the stock plastic hardware.
You'll have to crack open the DISA case to install the new parts. I gave everything a good spray down with silicone grease, and sealed the halves back together by applying a thin layer of 95% formic acid and clamping the halves back together. https://www.ebay.com/itm/1-Oz-30-ml-...4AAOSw~y9ZDHhy The 3IM install took a few hours, and for me was a bit tricky, but it's definitely worth it, wakes up the car a bit, lots more urgency above 4k rpm. |
03-13-2018, 01:39 AM | #4 | |
401
Rep 1,425
03-13-2018, 08:06 AM | #5 |
Save the manuals!
6016
Rep 6,746
$75 each.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
03-13-2018, 11:42 PM | #6 |
80
Rep 199
With shipping it came out to a little more than this ebay listing. I'm gonna wait for those ebay coupons to show up before buying
https://www.ebay.com/itm/182310972937?ul_noapp=true |
03-13-2018, 11:44 PM | #7 | |
Save the manuals!
6016
Rep 6,746
Noir883.00 |
03-14-2018, 12:49 AM | #8 |
80
Rep 199
Yeah I used that too on some blacked out kidneys haha. I actually messaged that seller right after the sale ended and he just restocked it. I'll wait for another $15 off $75 since that seems to come up more often.
03-14-2018, 01:09 AM | #9 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
I just used the high temp high strength JB weld and have had 0 issues lol
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
StradaRedlands4941.50 |
03-15-2018, 08:52 PM | #10 |
214
Rep 988
FWIW, I just installed a kit from that site to rebuild my larger DISA. The new flap and shaft has some considerable play, maybe 15 degrees worth of movement without moving the gears. Tightening it doesn't really make a difference and just seizes the flap from moving.
Please let me know if I'm doing something wrong lol
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
03-15-2018, 09:20 PM | #11 | |
80
Rep 199
might try your way to bond my current pieces instead of spending money on a rebuild kit |
03-18-2018, 10:12 AM | #12 | ||
2214
Rep 2,219
Drives: '08 128i
Yes! Sorry I glossed over the thread - I saw 'DISA rebuild' and tossed my experience in right away http://www.1addicts.com/forums/showthread.php?t=1457778 The current rebuild kits going around have both a metal shaft and flap that screw into each other. Quote:
Yes tighten it until it won't move. Trust me I went thru the exact same thing. My thought process is that there will be a moderate amount of force against the flap inside the manifold as air rushes by it, so it needs to stay almost airtight. I even went as far as taking a video of the valve to make sure it would open and close correctly.
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito Last edited by desertman123; 03-18-2018 at 10:47 AM.. |
03-18-2018, 10:29 PM | #13 |
42
Rep 551
Interesting on these rebuilds, I should have dug more on this earlier.
I just ordered a new large DISA as I have been replacing my oil separator (2006 n52 only) and related hoses. Came to find out that the DISA was exploded in my intake manifold when the garbage quality plastic pin dropped out of the throttle body mount point, and a began my state of panic. Luckily I identified it and it was the large DISA and not some internal piece of the manifold. I'm fairly sure a past mechanic saw this was broken and just put it back in the manifold without the flap on it. Which is a huge risk as that pin could shoot right into where the magic happens. I snaked the whole manifold with nothing to be found in there so that had to be what happened. The amount of cheap plastic in this engine is insane, so an aluminum rebuild is intriguing. End rant
2006 Sonora Metallic 330xi.
DIY: Charcoal Delete, K |
lab_rat394.50 |
03-19-2018, 12:24 PM | #14 | |
214
Rep 988
Anyone putting it off should really do it sooner than later, the crank was shot and the pin holding the top of the flap to the entire assembly was missing. While cracking the back open the flap just casually fell out.
03-26-2018, 09:56 PM | #15 | |
401
Rep 1,425
03-27-2018, 09:56 AM | #16 | |
Cometh
1090
Rep 1,305
Drives: Boy's Soul
Have you tested DISA valves using INPA before? I went to: Engine > MSV80.0 > F6 (Activate) > F1 (Actuator Activations 1) > Shift+F6 (VIMDISA) I connected each DISA valve to the longer cable (system 2) since the other cable was too short to be used for testing. I was able open both valves, but they would only close 33% when prompted (shift+F2). I'm not sure if this is normal behaviour... Here's a photo of the small valve at "33% closed" Last edited by The Nightman; 03-27-2018 at 11:11 AM.. |
03-27-2018, 10:52 AM | #17 | |
2214
Rep 2,219
Drives: '08 128i
PWM = pulse width modulation. It's like a dimmer switch for digital circuits. I'll do that, but I also heard both DISAs actuate when I got the tune installed
The Nightman1090.00 Blueeyesredpanda400.50 |
03-29-2018, 07:12 PM | #18 |
141
Rep 635
I have a used manifold, about 60k miles on it. You guys think I should just go ahead and rebuild as a precaution? Can I test the disa valves before I install and can they be removed with the manifold installed if I find out they are not functioning after the install?
03-29-2018, 08:25 PM | #19 | |
141
Rep 635
In the end though, If they are going to fail, I think it might be best to do it now instead redoing this whole process down the line. |
04-01-2018, 12:26 AM | #20 |
80
Rep 199
Just bought another vehicle so I've been busy with it instead of this project. Since the rebuild kit doesn't fix the actual issue, I'll be disassembling my valves and trying the JB Weld to see! Updates in the next couple weeks.
04-01-2018, 06:39 AM | #21 |
111
Rep 112
For information...as I have not seen this addressed on these forums.
BMW did a few updates on the valves during the production years of our cars. Based on superseded part numbers, the best I can tell is one update on the small, two on the large. The later valve variants have different shafts and bushings. The latest change occurred during 2007/2008. The large updated part number is 11617579114. The small is 11617560538. These numbers supersede the prior versions. I've sourced, tested, and sold 40+ of these manifolds for three stage conversions in the past year. In the case of the earlier valves, the large one is almost always disentigrated beyond 100k miles and requires replacement...as I do not rebuild valves for the 3im "kits" that I sell. I've never seen the later variants (years and part numbers given above) failed, regardless of mileage. One exception, I have RARELY seen the smaller valve of the newer design stuck open, but this will throw a CEL as it is recognized by the car. Disintegrated shafts and floppy valves are not noticeable to the computer. (I can see the OP has a part number ending in 538 and indicates the "stuck" problem.) I do not know if the stuck valves are indicative of a burned out motor or debris in the gears. I've only seen one failed in this manner and have not taken the time to tear it apart for further testing. I say this to say, if you can find later valves for your car (from X3, X5, Z4 Si, or n51) it's probably just as good or better than a rebuild on the earlier/superseded designs. I would suggest that precautionary rebuilding on later valves is unnecessary and that rebuilds due to failure will probably never be needed. Last edited by johnmyster; 04-01-2018 at 09:05 PM.. |
