03-08-2018, 08:27 PM | #1 |
432
Rep 939
Boost below target issues?
hey guys, my car has ran great for a couple years on JB4 and I run usually Map2 with downpipe and 93oct and I would always hit 12 or 13lbs. Then with 7 gallons on E85 I would run map7 and it would hit 17lbs. In just the last few weeks I can't get past about 9/10lbs. It shows l'm at least 4lbs below target. If I put it on map 7 i'm 8/9lbs below target. I was thinking it might be a boost leak so I checked all my connection for a boost leak and didn't see any.
I even tried running some E40, just incase I had some bad 93... Any insight? Here are some logs.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ Last edited by sly1types; 03-08-2018 at 09:02 PM.. |
03-08-2018, 08:33 PM | #2 |
432
Rep 939
Here is a log from January on Map2 where it was hitting the boost target.
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ Last edited by sly1types; 03-08-2018 at 08:57 PM.. |
03-08-2018, 09:07 PM | #3 |
BimmerPost Supporting Vendor
4920
Rep 115,999
Make sure to post these on n54tech as well.. Will get the BMS guys to look them over for you..
You checked the connection to the FMIC? throttle body connection @ charge pipe? Mike |
03-11-2018, 04:00 PM | #5 |
1106
Rep 1,499
You have a boost leak somewhere. You need to isolate and pressurize the air charging system and listen for leaks. Also, don't' forget that you could have a leak at the diverter valve.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
03-11-2018, 05:41 PM | #6 | |
364
Rep 775
OP, stock DV or did you install DV+ ?
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
03-11-2018, 05:55 PM | #7 |
432
Rep 939
I still have the stock DV. I think I might buy a smoke testing kit and see if there is an issue with a connection. Would smoke come out of the DV if its bad? or how do I test the DV?
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
03-11-2018, 08:16 PM | #8 |
not good, but bad
333
Rep 361
To add to this thread, what constitutes a boost leak? Are we talking greater than 2 PSI, or 4 PSI, or just not hitting target? Ask because my logs I'm often under by 1 to 1 and 1/2 PSI but sometimes over by that much as well.
Thanks! |
03-11-2018, 08:18 PM | #9 |
432
Rep 939
I used to always hit the target, now i'm always 4 to 5 lbs below. I have some screen shots above.
03-12-2018, 07:20 AM | #10 |
1106
Rep 1,499
You are good with +/- 1.5 PSI. If measured boost is 4-5 PSI below then you have a boost leak.
badbread332.50 louielouie544.50 |
03-13-2018, 09:28 AM | #12 |
3441
Rep 79,211
03-17-2018, 05:22 PM | #13 |
432
Rep 939
so i bought a smoke tester and pressurized the system to 5psi and didn't see any leaks. I'm thinking its the diverter valve?
Whats your thoughts/
04-08-2018, 10:20 AM | #15 |
432
Rep 939
Pressurized the system to 10psi, no leaks. Then I got the Diverter valve+ still didn't fix the issue. I'm thinking now its the boost solenoid/pressure converter...
Any thoughts?
04-11-2018, 12:51 PM | #16 |
432
Rep 939
I got the new boost solenoid in and it didn't fix it.
Any ideas? What should I check next? Do you guys think it could be the wastegate is out of adjustment?
04-11-2018, 01:21 PM | #17 |
1106
Rep 1,499
Can you pressurize to 15 psi? Sometimes leaks won't show up until it reaches a pressure threshold.
What smoke tester did you buy?
04-11-2018, 10:26 PM | #18 |
432
Rep 939
I used this one and its really designed for 2psi, so it was struggling at 10psi and the top would pop off. But it works well at 2psi.
https://www.ebay.com/itm/EVAP-Smoke-...72.m2749.l2649
JaredG_F301106.00 |
06-02-2018, 12:25 PM | #20 |
715
Rep 1,541
Your WGDC jumped up considerably from your old log to your new one. Sure sign of a boost leak.
