Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > buying used/cheap cats (both) for a 2010 e90 335i?
      03-08-2018, 01:36 PM   #1
shoopdawoop
Drives: E90 LCI Jet Black 335i
both my cat coverters on my car is out and looking for a pair that will pass smog check
      03-08-2018, 10:34 PM   #2
e92_bryan
Drives: ‘11 e92 328
Try looking into the dealership covering it, not sure about the n54 but with the n51 its covered under an emissions law in california, I think up to 100k miles maybe more, but basically the bmw is resonpisble for replacing my cats if they go bad before then
The warranty can be a loophole
Kinda how I got my oil filter housing, valve cover and oil pan gasket replaced 100% under warranty even tho my car doesn’t have an extended or cpo warranty
      03-08-2018, 11:40 PM   #3
shoopdawoop
yeah us federal emissions warranty is 8yr/80k (but im in California with their 7/70 warranty), although im pretty sure the us fed emission warranty still stands. problem is my p430/p420 error codes could be a result of a lot of things and not 100% that it's my cat converter at fault. sort of working in the dark
      03-08-2018, 11:43 PM   #4
e92_bryan
Drives: ‘11 e92 328
I didn’t know the warranty was the low
My car is a 2011 with 79 or 80k at the time I got everything warrantied
But me having the n51 it had an extra (no extra cost) warranty bc its a sulev
Not sure if the n54 has something similar
      03-09-2018, 02:55 PM   #5
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
the 7/70 has nothing to do with the 8/80 for cats.
It could be O2, but if your car failed smog with less than 80K on the dial, take it to the dealer.
I don't like Steven's Creek.
I go to East Bay and I have yet to have an issue with them.
You can experiment with your money all day long.
I would swap out the O2 sensors because they are fairly cheap and are not to bad to replace.
These are the sensors and they are all the same. The difference is that this sensor has long wires. Zip tie them out of the way. They work great. You will need a claw type O@ sensor tool.
:https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
If you change the sensors and you still have the same errors, then you need cats.
I'm well versed in auto diagnostics and don't have any issue figuring out what is exactly wrong before I spend money.
If you are at all iffy about diagnostics of emissions related issues, go to the dealer. You will probably save money.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
      03-10-2018, 11:35 AM   #6
Blown95ImpalaSS
72
Drives: s54 e36 m3/4/5
I'm in SF and have 2 oem cats from a n54 135i midpipe. Want to have an exhaust shop weld them in for a few bucks? PM me if you like
      03-24-2018, 01:49 AM   #7
Jeffn54
Drives: E90 335i
Did you ever find cheap oem downpipes?I have a set $40 and pay for shipping
      03-27-2018, 07:41 AM   #8
shoopdawoop
I actually got some from a friend. but am still looking around for cheap labor
