Valvetronic Motor Gasket Replacement?
03-05-2018, 05:08 PM | #1 |
1051
Rep 782
Drives: 2010 328ix E91, 2011 128i E82
I posted over in general but was redirected to post here for a better chance of relevant response.
I have a 2010 328i X-Drive E91 with 120,000 miles. Tracking down the various leaks and pulled the engine cover. It does appear to be coming from the valvetronic motor so it looks as though that gasket is done. Online DIYs say that when repairs are performed on the Valvetronic assembly, the limit stops have to be relearned and a BMW scan tool is needed to do this procedure. But it also says that when just removing the motor to replace the gasket you are not changing the mechanical position of any Valvetronic assembly components, so a relearn is not always needed. How often would a relearn be necessary? If the scan tool for a relearn is not necessary, then it is a DIY for me. Also, once the replacement is done, how will I know whether a relearn is necessary? Will it not start? Will it start but sound/run terribly? Will it start but the engine will explode into a million parts, piercing my body with engine shrapnel (which would be preferable to facing my wife and telling her I need a new engine)? I've ordered a new gasket and have tracked down a couple of DIY's for this job so I am ready to go, probably this weekend. I do have someone who probably could help me out with a scanner to do the relearn but it would be a while before that could be set up. So, I'm hoping I can do the replacement without the relearn. K9Leader |
03-05-2018, 11:23 PM | #2 |
84
Rep 777
I did this 2x, both time replacing the motor. While it's been a while from what I recall: You don't need any tool to do the re-learning, the car does automatically the checking and finds same stops. From my notes after the replacement: Turn key to ON position for 30 seconds, then OFF, then ON again for 30 seconds before starting vehicle. Be ready to do some full adaptation resets via INPA if things go South, but I think you're safe.
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
03-06-2018, 08:01 AM | #3 | |
996
Rep 2,287
Use an Allen key to turn the valvetronic motor during removal and replacement. Follow the TIS. |
Taskmaster2465.00 |
