MHD help
02-25-2018, 09:10 PM | #1 |
257
Rep 674
MHD help
Hey guys,
here is the issue. I am looking forward to tune my 2011 335xi N55 sedan and I am pretty sure I will go with MHD flasher. The problem is that I live in Canada and I do not understand what king of map I need to get in order to respect my octane rating. I run on 91 in Ottawa. I don't know what all of these acronyms like ACN, CAD, OCT, RON stand for as well as the 2 different numbers for each map. I would like to know what I am doing before messing up with my car. Thanks for your time and help. |
02-26-2018, 08:28 AM | #2 |
718
Rep 1,753
You live in canada like me and we have very bad 'winter gas'. With butane. You need to use the California gas map 91 Octane.(ACN) Unfortunately in ontario we dont have E85. That would change everything.
02-26-2018, 11:29 AM | #4 | |
718
Rep 1,753
Keep an eye on timing corrections from logs. I can show you what that means if your not sure. It also takes some time before the DME adjust for new gas. Resetting octane adaptations speeds up this time. |
02-26-2018, 11:34 AM | #5 | |
257
Rep 674
Honestly I would really appreciate if you could. It will allow me to monitor the car's status which is very important for me. Thank you. |
02-26-2018, 11:56 AM | #6 |
718
Rep 1,753
Np at all please private message me i can give you my email address. I can show you actual comparisons. Its easier to help that way. I am pationate about this platform and will show u anything i know. How to also monitor any potential causes of misfires or other issues. I was able to pinpoint rough idle issues i had during cold start. It was intermittent.
02-26-2018, 03:58 PM | #7 |
Rep 33
Could I ask for some assistance too? I don't know what to look for in the MHD logs for knock. Unfortunately live in Nevada so I will be running ACN maps especially in the winter. Would like to try regular 91 in the summer but want to keep an eye out to make sure I'm not compromising longetivity.
02-27-2018, 08:37 AM | #8 | |
718
Rep 1,753
if you have a timing COR (corrected) set up. Ideally you dont want to see any negative values. Always 0. But -3 degrees on 2 cylinders or 3 is OK. More than 3 degrees negative on more than 3 cylinders is not a good situation. It most likely means you gas is not good quality (high enough octane) Also its important to note that when you are its under FULL wide open throttle and the car has reached operating temperature. Partial throttle timing pulls are more complicated we wont get to hose. We are looking at full throttle and boosted corrected timing. Let me know if you have any other questions. If the app is displaying actual timing values CKP for all cylinders then reading that is a bit different. I can explain that as well. Let me know. |
03-10-2018, 11:45 PM | #9 | |
166
Rep 429
Drives: 2011 e92 335xi
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
03-12-2018, 12:38 PM | #10 | |
718
Rep 1,753
Timing corrections happen when Knock sensor (Narrow band microphone nothing else) detects a knock. DME retards the timing to avoid engine damage/ DTC is traction control.. completely different systems not related. |
Supermoon166.00 |
03-12-2018, 01:32 PM | #11 |
324
Rep 2,014
You should definitely completely disable traction control when logging. The traction control (even DTC) will cause throttle closures and other performance issues that are counter productive to your logging.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
Supermoon166.00 |
