02-22-2018, 11:16 AM | #1 |
24
Rep 53
Wheel offsets?
Anybody knows the wheel offsets for the F90? Wondering if it is going to be similar to the F10.
I know the F10 is: 9Jx20 ET34 10Jx20 ET34 |
02-22-2018, 11:45 AM | #2 |
1310
Rep 2,349
The F10 offsets are actually 32mm front and 34mm rear.
The F90 is 28mm front and rear for the 20" option and weirdly 26mm front and 28mm rear for the 19" option. |
02-22-2018, 06:13 PM | #3 |
24
Rep 53
02-22-2018, 07:10 PM | #4 | |
Plenipotentiary
2614
Rep 3,046
PCD 5x112 CB66.56 Front: 19x9.5 ET26; 20x9.5 ET28; 19x9.5 ET26 (winter EH2+ bead profile) Rear: 19x10.5 ET28; 20x10.5 ET28; 19x9.5 ET26 (winter EH2+ bead profile) F90 is rather aggressive with the fitment out of the box. In service diameter in the front is close to the scrub radius limit while the rear uses up every legal millimeter and then some through the addition of arch extensions extending out over the factory rolled wheel well. |
02-24-2018, 12:50 PM | #5 | |
1310
Rep 2,349
The F06/12/13 M6 is 19mm offset on the rear 10.5" wheel options. It comes down to hub location compared to fender location. In the M6 the hub is massively moved inwards compared to the 640i, 650i, 640d and B6 as they have a number of differences - I think mainly the hub was changed. |
02-24-2018, 12:53 PM | #6 | |
1310
Rep 2,349
Are the current 20" wheels forged? I tracked down the weight of the front 19" wheel at 13kg which is quite heavy when compared to F80/F10/F13 forged options |
02-24-2018, 02:31 PM | #7 |
168
Rep 454
I just ordered my M5 today (my first Bimmer!), very excited. I have the wheels from my previous Audi S4 and would like to know if it will fit the F90 M5 as I plan to use it as my winter rims.
Forgestar F14 19 x 9.0 +40 offset all around. Last edited by neohh; 02-24-2018 at 07:25 PM.. |
02-25-2018, 11:19 AM | #8 |
1310
Rep 2,349
They might do with a big enough spacer. Caliper clearance will be an issue and you won't be able to find anything concrete until you actually try it.
02-26-2018, 12:55 PM | #9 |
24
Rep 53
theoretically impossible without spacers
03-02-2018, 05:17 PM | #10 | |
Plenipotentiary
2614
Rep 3,046
All 3 wheel options available right now are cast (19" Square Winter, 19" Staggered, 20" Staggered). |
03-02-2018, 06:29 PM | #11 |
288
Rep 604
Any thoughts on fitment using F10 M5 343 wheels?
Front wheels: 20x9" ET34 Rear wheels: 20x10" ET34 I already have a winter tire and rim setup with these, and would love to use them on the new F90. I wonder what the chances are of the old tire pressure sensors being recognized by the new M5. |
03-02-2018, 06:38 PM | #12 | |
Plenipotentiary
2614
Rep 3,046
03-03-2018, 06:17 PM | #16 |
1310
Rep 2,349
The only BMWs with that pattern are the G11/12 7 series, G01/02 X3/X4 and G32 6 series as well as obviously the G30 5 series.
All new launches will be 5x112. |
03-04-2018, 11:43 AM | #18 |
Plenipotentiary
2614
Rep 3,046
03-04-2018, 12:58 PM | #19 |
168
Rep 454
10-24-2018, 01:09 AM | #20 |
Rep 21
would anyone be able to let me know if a 19 x 9.5 et25 would work in a square setup? I know the new bmw winter setup is et26, but not sure whether this would be cutting it close at the rear given oem is et28.
cheers! |
10-24-2018, 01:31 AM | #21 |
1310
Rep 2,349
I’m sure you’d be fine with 265 or 275 wide tyres all round
10-24-2018, 02:18 AM | #22 |
Rep 21
I'm not so concerned with the tire as i am with the offset.
There's not a lot of cheap wheels available on the market at the 26mm offset and I'm trying to figure out whether I can use ones at the 25mm offset without hitting brakes, etc. There's more wheels in the et30 so not sure whether those will work too. unfortunately, bmw is all out of stock of the winter tire setup and I'm trying to hack something together before the snow starts falling |
