Low grumble at idle on start
02-22-2018, 11:04 AM | #1 |
142
Rep 337
Last week I started noticing a low grumbling sound at idle after starting the engine. it's not the blower motor as I have the fan off. The noise seems to go away as the idle settles and is also not noticeable at higher revs.
It may just be coincidence, but I started noticing it right after doing an oil change. All I did was oil & filter and check the air filter (k&n drop in, looks clean). Any idea what this would be? Any cause for concern? |
02-22-2018, 11:09 AM | #2 |
142
Rep 337
Actually just tested a bit more. It doesnt seem to go away as the idle settles. Also I still notice it if I rev the engine a bit in neutral. It's harder to hear and definitely doesn't build as revs increase, but it's there.
02-22-2018, 11:39 AM | #3 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Can you look around the engine bay with the motor running and try and hear where it's coming from?
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
dancing__narwhal141.50 |
02-22-2018, 11:47 AM | #4 |
Resident Pedant
503
Rep 792
Automatic or manual? With manual cars, it's normal to hear some noise coming from the clutch/trans when the clutch is engaged and the transmission is in neutral.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
02-22-2018, 03:04 PM | #5 |
142
Rep 337
It's a manual. Happens with clutch in or not, and in gear or in neutral. I never noticed it before is the weird thing.
02-22-2018, 03:05 PM | #6 |
142
Rep 337
02-23-2018, 10:24 AM | #7 |
142
Rep 337
I noticed yesterday that it seems to happen most consistently when i first start the engine (even if it was already warm) and then seems to have gone away after some driving. Not sure if this is always the case but that's what I noticed.
02-23-2018, 11:12 AM | #8 |
2214
Rep 2,219
Drives: '08 128i
I'd take the belt off and inspect the pulleys.
02-23-2018, 11:26 AM | #9 |
964
Rep 3,854
Drives: 330i, 135i
