Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 2BDE fuel high pressure shadow code
      02-21-2018, 11:09 AM   #1
Chmilar
14
Drives: 2011 335xi FBO
so I'm getting this shadow code
2BDE Fuel high pressure on enabling of injection: pressure to low.
can't find much online about it
I have what I consider longer then normal cold starts and a little hesitation when I hit the gas. HPFP drops about 2-400 psi when I first hit the gas
anyone else experience. Hpfp going out ?
      02-21-2018, 11:18 AM   #2
Johnny Boost
324
Drives: '21 M850i GC
I get the exact same codes. I have a newer hpfp and lpfp. The only response from the MHD guys is to reset your adaptations which doesn't fix anything. Hopefully it will get worked out in the future.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      02-21-2018, 11:25 AM   #3
Chmilar
14
How's your cold starts. any indication if HPFP going out? I reset adaptations quite often and it does nothing
      02-21-2018, 12:50 PM   #4
MacE90
MacE90's Avatar
36
Drives: Chevrolegs
2011 335i xdrive  [10.00]
I started to throw this code while experiencing long cranks (3-4) before it would start. I replaced the hpfp which resolved both the long cranks and 2BDE code.
Appreciate 2
      02-21-2018, 01:44 PM   #5
Johnny Boost
324
I had long cranks periodically before the new hpfp and lpfp, and I still have them today.
      02-21-2018, 03:28 PM   #6
Boo$ted_in_ri
30
Drives: 2011 335i
Had the same code with a few others. Replaced my hpfp and now it’s running great. Had the long cranks and car was running terrible under full throttle. Resetting adaptations won’t fix the problem long term if at all.
      02-21-2018, 03:38 PM   #7
Chmilar
14
were you getting timing corrections at WOT ?
      02-21-2018, 05:15 PM   #8
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
Also curious about this. I have the shadow code and very long cold starts along with timing corrections on almost all of my tunes.
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
      02-21-2018, 05:20 PM   #9
Chmilar
14
this is my exact issue man. even threw in e85 to test with same issues as I figured it was octane. (but it did help ) wondering if this code is because of HPFP. And HPFP is causing my timing corrections
      02-22-2018, 07:41 AM   #10
SnapCoupe
BMW Portland
I have been chasing down this issue since I purchased the car to no avail. Anytime it is below 50 degrees and the car has been sitting for more than 3 hours it will experience a long crank. I have tried priming the fuel pump twice (unlocking car, opening door, closing door, locking car) and pressing the ignition before starting the car (manual) but neither of those help the issue. In these conditions the car will either take 5 seconds or more to start on the first crank, or will continue to crank until I press the button once again to stop it, and one more time to restart it. On the second crank it ALWAYS fires up immediately.
All of my logs show signs of normal fuel pressure and nothing out of the ordinary. I work at a BMW dealer and have tried multiple times to get the pump to throw a code to get a fuel pump partly covered under extended warranty. The only thing I see is the shadow code. I have yet to test and see if there are timing corrections on my stock map, but they are present in every version of my custom 92 octane map, as well as in the MHD OTS maps.
      02-22-2018, 11:15 AM   #11
vespa
217
Drives: 2011 335i
Has anyone ever figured out what a "shadow code" is? I asked MHD but they wouldn't say. It seems odd that somehow MHD is able to read codes that can't be seen by ISTA, yet MHD doesn't know what they are reading, why, or how.
And this probably isn't the best thread for this, but has anyone ever seen a car *without* this "shadow code"?
      02-22-2018, 11:18 AM   #12
Chmilar
14
i was advised by another member that after replacing his HPFP the code went away and car went back to Normal.
but it's super annoying not knowing for sure if this code is causing issues
      02-22-2018, 12:52 PM   #13
Boo$ted_in_ri
30
Drives: 2011 335i
My car had all these symptoms. Sometimes under full throttle my fuel pressure would be on point and other times the car would skip and bog down. Long cranks and no check engine light just shadow codes. Due to the hpfp actin up it messed with my pre cat 02 sensor. The senor is in charge of long term fuel trims and cold starts. So once I replaced both my car has been 100% since.
      02-22-2018, 12:53 PM   #14
Boo$ted_in_ri
30
Drives: 2011 335i
If all you have are shadow codes for hpfp like I had and fuel pressure, I hate to tell you but your hpfp is going out the door.
      02-22-2018, 01:09 PM   #15
Chmilar
14
So. hpfp shadow code. long cranks and hesitation when hitting the throttle. it's safe to say HPFP ?
      02-22-2018, 01:30 PM   #16
Boo$ted_in_ri
30
Drives: 2011 335i
Very safe to say it’s the hpfp. I had all these signs everyone is saying above. And even threw a half engine light and had reduced power. Reset codes and adaptations and it went away but the symptoms stayed. I went through the dealer for the part it was 1250$ with a 400$ core so 850$ once my old one was out. Certain things I don’t care how “oem” they are I’ll always go to the dealer for.
      02-22-2018, 02:30 PM   #17
Johnny Boost
324
When's the last time you checked your codes? I had HPFP replaced by the dealership and still get those codes...
      02-22-2018, 03:32 PM   #18
Boo$ted_in_ri
30
Drives: 2011 335i
Been checking everyday put the new pump in a week ago. No codes or problems. Did you reset all your adaptations wants the pump was in
      02-22-2018, 03:34 PM   #19
Johnny Boost
324
Yes I've reset adaptations and cleared all modules. Please keep us posted if the codes come back.
      02-22-2018, 08:30 PM   #20
SnapCoupe
BMW Portland
My dilemma is in regards to having a "real" code pop up for the HPFP. BMW's diag software doesn't pull anything up related to the shadow code that MHD is showing. If my car was throwing a code for the HPFP I would have it replaced already, but I really don't want to replace it fully out of pocket if there is a potential I can get most of it goodwill'd.
How is it possible that MHD can see this code yet BMW's software cant?
      02-22-2018, 08:50 PM   #21
Chmilar
14
Did you experience timing corrections at all with the bad hpfp. Did they correct after new pump ?
      02-22-2018, 09:17 PM   #22
Boo$ted_in_ri
30
Drives: 2011 335i
To be honest I never logged a pull after my car sputtered when I got on it hard. I was afraid to damage the motor with the lack of fuel. I saw the shadow codes come up and just replaced the pump.
