BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Change 3 to 5 blink turn g30
      02-20-2018, 07:19 PM   #1
alegsxr
alegsxr's Avatar
Italy
10
Drives: BMW 530xd M-Sport
Hi all,
i read some post and the coding maybe this:
BDC Body Module 3069 LceConfiguration PIA_DEFAULT_TIPPBLINKEN and set Werte=2. Werte=1 is for 3 blinks and Werte=2 is for 5 blinks.
HU_NBT 3000 5_FACH_TIPPBLINKEN
I can see the option in iDrive but i can't select.
When i try to code PIA_DEFAULT_TIPPBLINKEN to Werte=02 it revert to 00 after code fdl.
There is a new coding tested?
Thanks
      02-25-2018, 11:13 AM   #2
alegsxr
alegsxr's Avatar
Italy
10
Nothing? Almaretto? can you help me please?
      02-26-2018, 12:23 AM   #3
valrossi
Drives: F10 523
Attempted to FDL code. showing 5 times in idrive but cannot be selected, also the value went back to original after FDL coding in BDC.
Is this function not workable for G30?
Please help....
      02-26-2018, 12:40 AM   #4
AP
AP's Avatar
2777
Drives: G30 M550
Whilst I cannot give you an answer I'm pretty sure that is was impossible on the f10 but did work on the f30.
Not sure that actually helps you though!
      02-26-2018, 01:42 AM   #5
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by alegsxr View Post
Hi all,
Thanks
Bitmask dictates acceptable werte values.
If IDrive came with option to select 5, it is possible to change. But coding results in menu that cannot be selected.
      02-26-2018, 02:15 AM   #6
alegsxr
alegsxr's Avatar
Italy
10
OK thanks, and which is a possible solution?
      02-27-2018, 12:40 AM   #7
Almaretto
Almaretto's Avatar
2374
Updating firmware.
      02-27-2018, 04:06 AM   #8
alegsxr
alegsxr's Avatar
Italy
10
Updating firmware.
Of the car?
      02-27-2018, 08:43 PM   #9
Almaretto
Almaretto's Avatar
2374
Of the car?
Yes.
      02-28-2018, 02:21 AM   #10
alegsxr
alegsxr's Avatar
Italy
10
Yes.
      03-26-2018, 08:33 AM   #11
alegsxr
alegsxr's Avatar
Italy
10
Yes.
Good Almaretto...i have updated the firmware but i have the same problem.
Do you have coded 5 blink in your G30?
      03-26-2018, 03:05 PM   #12
TCBKindh
Sweden
12
Drives: G30 530D
Trying to update to upd09031 but idrive say its not compatible with my vehicle.
Anyone has the same problem ?
      03-26-2018, 06:25 PM   #13
Almaretto
Almaretto's Avatar
2374
I will find out when i order one in a few years.
540iSUP704.00
      03-27-2018, 04:58 AM   #14
alegsxr
alegsxr's Avatar
Italy
10
ops...sorry
      03-28-2018, 02:09 AM   #15
Almaretto
Almaretto's Avatar
2374
Hi all,
For F015, setting PIA_DEFAULT_TIPPBLINKEN to 02 gives 5 blinks.
In G30 CAF, bitmask prevents any werte other than 00 and 01.
For the HU_NBT2 FDL, boolean suggests there are no conditions for the G30 where 5_FACH_TIPPBLINKEN is aktiv.
      04-25-2020, 10:42 AM   #16
TNLB7
Drives: BMW E92 325i 2007
Does anyone have an update on this since last post?
My friend would really like to get 5-times blinking activated on his G32! Did it ever get added to a software update?
      05-17-2020, 06:57 AM   #17
Evelyn Powell
Evelyn Powell's Avatar
8
Drives: G30
Would be really useful if I had 5-blink on one-touch turn signal Anyone figured it out?
      01-09-2023, 01:42 AM   #18
BMW5and7
1059
Drives: X7;X5;S-Class;Navigator
So, has anyone been able to fix this issue and code 5 blinks turn signal on the pre-LCI G30?
      01-09-2023, 06:08 PM   #19
SadExBimmerOwner
Drives: 535i xDrive M Sport
This is a routine and common programming change on bimmercode and it’s not even in the custom menus. Not sure how to do it otherwise
      02-02-2023, 05:14 AM   #20
Almaretto
Almaretto's Avatar
2374
Everything Bimmercode can do, E-sys can as well and more.
      02-05-2023, 01:58 AM   #21
G30M
G30M's Avatar
3772
Drives: BMW M550i; Kia EV6 GT
just did it with bimmercode one click
      02-05-2023, 03:57 PM   #22
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
Coded 5 blinks? Do tell the coding.
5post
