BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > CEL light after DP Install
      02-17-2018, 01:27 PM   #1
NDB24
Drives: 2016 340i xDrive
What's up. Recently installed VSRF downpipe with the intentions ordering JB4 to remove the light. However, I've found out that JB4 does not allow you to remove that light with the new firmware update.
Will MHD clear the CEL?
Thanks!
      02-17-2018, 03:20 PM   #2
RoarinForeign
Drives: 2011 e92 335i xdrive
Yes mhd can clear it. I believe if you change a few values in winkpf you can clear it out for the jb4 as well. Very easy to do with MHD you just check/uncheck the box for it before flashing
      02-17-2018, 09:18 PM   #3
MTK24
MTK24's Avatar
485
Drives: 2011 335I X Drive
Did you order the CEL delete from VRSF as well?
Vermillion Red
      02-18-2018, 09:48 PM   #4
NDB24
No, I haven't ordered the fix. My worries are mainly if I will be able to pass inspection in NY.
      02-19-2018, 10:55 AM   #5
OneMoreAlex
OneMoreAlex's Avatar
45
Drives: 2012 e92 335i
JB4/MHD will suppress the CEL light coming up. Keep in mind this is not a 'fix', the code will still be there. You will not pass emissions since the monitor will be in an incomplete state.
To pass you will need some sort of DP fix...there's a few options out there.
12' 335i
| CP-E CP | MHD | VRSF DP | ALPINA B3 |
      02-20-2018, 11:40 AM   #6
nynyny
Drives: 2011 335i xDrive E92
Didn't BMS remove JB4's ability to autoclear codes and the CEL?
      02-20-2018, 11:55 AM   #7
Wksk
79
Drives: 2013 335i e92 6spd goes vroom!
Yes, you can add it back via a few methods though.
      02-21-2018, 10:12 AM   #8
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
MHD nor JB4 will allow you to pass catless, only going back to stock or having a DP Fix.
However, if your state inspects visually or actually sniffer it still might not pass.
      02-21-2018, 01:32 PM   #9
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Thanks!
There is a DP fix for the N55 you can wire in..
Mike
      02-21-2018, 01:33 PM   #10
Mike@N54Tuning.com
4918
Yes a few have posted a work around Didn't take long for the BMW hackers.. LOL
Mike
      02-21-2018, 03:27 PM   #11
NDB24
Mike
Appreciate the help! I'll proceed using the DP fix from VSRF.
      02-21-2018, 03:33 PM   #12
MTK24
MTK24's Avatar
485
That’s not something you want to use every day. It alters fuel trims levels.
You only use that before emissions.
      02-21-2018, 05:41 PM   #13
NDB24
Correct, I've read similar posts suggesting to do the same. Thanks!
      07-02-2019, 12:05 PM   #14
Wiz992
Oman
13
Drives: F33/15
CEL appeared after installing DP fix
Hey guys..
I know it's an old topic but i need some support on this:
I installed N55 downpipe on my F33 4 days ago and installed the dp fix yesterday.However, the CEL appeared today while driving. My question is, did this happened because of the previous average readings (for the past 4 days) ?
And will it disappear by itself or i have to clear it ?
Note that, i have carefully installed the fix by following the instructions and the LED is on.
Thanks
