Car keeps over heating after repairs!
02-16-2018, 09:42 AM | #1 |
147
Rep 796
I need some help guys, i changed the water pump tstat and all and then my car still over heated (i didnt drive it about a month cause of weather) 3 weeks ago it over heated took it back to my mechanic he said water pumps still good its the radiator. Picked up my car today and drove about 12 miles and reached my neighborhood when the yellow engine temp light came on i pulled over turned it off for a couple mins then back on. 10 mins driving comes back on and then goes away after couple of seconds. Could this be a sensor issue? Or has anyone had an experience like this before?
02-16-2018, 12:23 PM | #2 | |
964
Rep 3,854
Drives: 330i, 135i
02-16-2018, 01:29 PM | #3 | ||
147
Rep 796
02-16-2018, 01:31 PM | #4 |
964
Rep 3,854
Drives: 330i, 135i
02-16-2018, 01:56 PM | #5 |
147
Rep 796
Ill get ghat checked out thanks
02-16-2018, 08:11 PM | #10 |
25
Rep 38
Can you explain more? I'm waiting on a new water pump & t-stay to install cause of similar issues as OP, but I also noticed no heat blowing through the vents the day I got all the codes & overheated.
02-16-2018, 11:02 PM | #11 |
480
Rep 1,600
Air is a poor carrier of heat. If there is an airlock, you won't get coolant to your heater core and other areas. You rarely get air into a system that has been running properly for a while. It is usually immediately after a repair to the cooling system.
But a dead coolant pump will also cause a similar symptom. |
02-19-2018, 02:27 PM | #12 |
147
Rep 796
Mechanic replaced the fan and said it ran for about 20 seconds and then stopped and smoked...theyre saying its an electric problem causing the fan to stop working...going to be an expensive bill
02-19-2018, 06:32 PM | #13 | |
718
Rep 1,753
Car should not be started after any coolant refill before doing bleeding twice at least. |
