Any clarification on spring rates?
02-07-2018, 07:02 AM | #1 |
8
Rep 166
Some time this year I plan on overhauling the suspension; bushings, coilovers, alignment, etc. but it seems there are differing opinions on spring rates for the e90. Some guys say stick 1:3, some say go 1:2, few say 1:1, even fewer are approaching 1:4.
I’m 99% set on going with FA500’s. My car will probably never see the track, but I drive more spirited than I should on the street, approaching track classification. I want to close the fender gap a bit, which it seems all coilovers do enough for what I want. Where should I go with my spring rates? Also, what’s the difference in springs that come with the kit by default and “Swift” springs? Thanks for any insight and can’t wait to upgrade! |
02-07-2018, 07:23 AM | #2 |
Photographer
412
Rep 2,643
Swift springs are made differently to conventional springs, and in theory are of a higher quality.
I'd go at the very least for 1:2 for a road car, so 6k/12k would probably be a nice road rate. I think whilst 1:3 might be more technically balanced, I'd be worried it might be too stiff on the rear for the road. |
02-07-2018, 02:36 PM | #3 |
953
Rep 2,672
Drives: e92 + f15
Let me know if you have any questions on the FAs. I have the 500s, all of their options, swift springs 8k/14k after some trial/error and learning some suspension math. Their stock rates don't work well on this chassis IMO. Had them for 2+ years now, 90% street, 8% backroad attack, 2% autoX.
I'd probably go 6k/14k from what I've learned now. |
eetadik22.50 |
02-08-2018, 07:51 AM | #4 |
8
Rep 166
Thanks fellas!
026z- do you feel all the options were worth it? Can you describe your setup to what 6k/14k should feel like? I’m guessing 6k should be a little more supple.... Do you also have m3 bits on your car or sway bars? My vehicle has hotchkis sways, m3 front bits... Thanks! |
02-08-2018, 08:23 PM | #5 | |
953
Rep 2,672
Drives: e92 + f15
M3 bits, I have the Front Strut Tower Brace (kinda necessary as the FA front adjustment knobs would hit the stock braces) and rear lower control arms (had FA spec my setup for M3 rear struts). The rest of the M arms are going in this Spring. |
02-09-2018, 09:03 AM | #7 |
8
Rep 166
Can you elaborate a bit more on your experience feuer? 5/9 is way different than anything I have seen/heard other than being nearly 1:2....
026z- what strut brace are you using? |
02-09-2018, 09:18 AM | #8 |
4276
Rep 9,206
I don't have personal experience. They came on a car I'm parting out. Says Swift 050 that stands for 5k. Or at least that is what I've been told.
02-13-2018, 10:12 PM | #10 |
953
Rep 2,672
Drives: e92 + f15
02-14-2018, 01:17 PM | #11 |
23
Rep 31
Zero, glad to read your feedback on the spring rates. I have a 09 328i xdrive and I am close to ordering the FA500's with Swift springs and all the extra goodies. After reading your feedback though, I may go lower on the front and higher on the rear But I'm not sure if it will work out the same from RWD to AWD. I've been doing suspension math for the last few days so my head is spinning...
It seems that an 8k/12k setup keeps the same relative spring ratio from front to rear the same, I just am worried its still going to be oversprung. I want as stiff as I can go before "pogo-ing". |
zero2sixtyZ952.50 |
02-14-2018, 02:29 PM | #12 |
953
Rep 2,672
Drives: e92 + f15
@motiv7891 joeybutts
Take a look at this thread I made a while back. This was before revalving the rear struts to match for the 14k rear spring change. I posted some of the calcs and a lot of good info from other members. Short travel coilovers (front) change motion ratio? http://www.e90post.com/forums/showthread.php?t=1359653 |
02-18-2018, 07:12 PM | #13 |
8
Rep 166
0260Z - does it matter that you are in an e92 and i an e90? HAve you made the switch to 6/14? Im hoping fall to do all inserts and coilovers, so have time.
02-20-2018, 02:57 PM | #14 | |
953
Rep 2,672
Drives: e92 + f15
Still 8k/14k at the moment. Might switch to 6k front later when I need to take apart the front setup. After last auto-X (which was on a rough surface), I was happy with the handling/dive. Tire pressures should've been set a bit higher though... |
