3 stage intake manifold additional Oil separator
02-05-2018, 01:19 AM | #1 |
401
Rep 1,425
Bought a 3IM but its the older version which has one outlet. It comes with an oil separator, i know 328i already comes with a oil separator. But would it be possible to use this oil separator that comes with the 3IM. As i was removing the 3IM, there's some oil in the 3IM, so I thought it'd be better to separate the oil just like a OCC.
02-05-2018, 09:25 AM | #2 |
3973
Rep 7,215
I don't think so. you already have an oil separator - it's just built into the VC. it works basically the same.
A little bit of oil residue in the manifold is normal and harmless. Now if there's a pool of oil in your actual engine you might have some problems.. |
Blueeyesredpanda400.50 |
02-05-2018, 09:55 AM | #3 |
111
Rep 112
If your car is 2007 or newer, you're going to need a two port manifold.
Single port manifolds and double port manifolds were both used with external separators, so you can buy the adapter hose to make either manifold. Only dual port manifolds were used thereafter (oil separators internal to the valve cover.) |
02-05-2018, 10:21 AM | #4 | |
1007
Rep 2,108
The thing with a single port manifold or double port manifold, the vacuum hose goes from the manifold into the external oil separator (assuming it is 2006/2005 model with external oil separator). And hose from behind the valve cover goes to the other side of the oil separator. So if there is any "hose adapter" it would be the external oil separator itself I personally would look for a two port 3 stage IM at car-part or lkqonline. They are not that expensive if you search and look around, and used in a wide varity when you include the N51's in the mix. |
02-05-2018, 10:27 AM | #5 |
111
Rep 112
Phase P, my response is correct, although a typo makes it confusing to read.
BMW part number 11617522933 is a hose that goes from a single port manifold to an external oil separator. BMW part number 11617559530 is a hose that goes from a double port manifold to an external oil separator. BMW part number 11157559528 is a hose that goes from a double port manifold to the valve cover for an "internal" separator. The fourth option, the one the OP wants, does not exist (to go from a single port manifold to the valve cover in the case of the later "internal" oil separator.) |
Blueeyesredpanda400.50 The Nightman1090.00 |
02-05-2018, 12:11 PM | #6 | ||
401
Rep 1,425
Some threads I read: Single breather type manifold installed on 2009 328i, the owner used a rubber stop for the extra hose outlet. But I probably don't want to go this way. http://www.e90post.com/forums/showthread.php?t=939530 Now i get it, to go from a single port manifold to the valve cover in the case of the later "internal" oil separator does not exist Other than plugging it with a rubber stop or buying a 2 breathers type, I dont have any other option right? Last edited by Blueeyesredpanda; 02-05-2018 at 01:01 PM.. |
02-05-2018, 04:37 PM | #7 |
20
Rep 77
Why not? I've done this as well as many others and have been problem free for years. I followed the instructions in the link (minus the zip tie) and have been totally fine.
02-05-2018, 05:43 PM | #8 |
401
Rep 1,425
So this Y hose is connected from the back of the valve cover to the single breather and the other opening will be plugged.
02-07-2018, 08:22 AM | #9 | |
20
Rep 77
02-19-2018, 09:44 PM | #10 |
Save the manuals!
6015
Rep 6,746
I'm a but confused now. I have a 2009 328i with the N52 motor, and a 3 stage manifold. Will I need to modify/plug any of these hoses as mentioned in this thread? I thought it would be a straight forward plug and play swap for my car, so I was about to attempt the swap tomorrow. If there's anything else I should be aware of, that would be great! It's finally warm enough for a change to DIY this in the garage.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
02-19-2018, 09:55 PM | #11 | |
401
Rep 1,425
02-20-2018, 12:30 PM | #12 |
69
Rep 154
Any idea what years / models the two port 3IM are in? For instance, I have a 2009 so according to above I need a 2 port 3IM. If I source it from a 2006 330i will that be completely plug and play?
02-20-2018, 01:02 PM | #13 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Anecdotal evidence: my 3 stage was from a 2008 X3 and it was 100% bolt in to my 2008 128i.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
02-20-2018, 01:27 PM | #14 | ||
401
Rep 1,425
Here's a pic comparison. Single outlet Single outlet with hose Single outlet with hose connected to the oil separator which ALL 328i already have one internally. Double outlet Double outlet hose for external oil separator Double outlet hose for 328i INTERNAL oil separator Last edited by Blueeyesredpanda; 02-20-2018 at 01:33 PM.. |
02-20-2018, 10:19 PM | #16 |
1007
Rep 2,108
According to real oem.vom, only 2005 and some January 2006 build date 330’s had single port intake manifold. Later build dates are the current manifold with two ports. This lists the part number and on which models and years it is found :
http://www.realoem.com/bmw/enUS/partxref?q=11617559523 |
6ixSpd6014.50 |
02-20-2018, 11:00 PM | #17 |
Save the manuals!
6015
Rep 6,746
Guess I'm lucky and mine is the dual port setup. I should be good to go!
02-20-2018, 11:34 PM | #19 |
Save the manuals!
6015
Rep 6,746
Yup, no issues with them.
02-21-2018, 10:07 AM | #20 |
69
Rep 154
6ixSpd,
Let us know what you think after your install and ECU tune (to take advantage of the DISA valves). I am really interested to see what you have to say, especially given our recent PM discussion. |
02-21-2018, 11:18 AM | #21 | |
Save the manuals!
6015
Rep 6,746
I'll be doing a dyno before (stock except for intake and muffler) and after (3SM, tune, potentially headers as well).
02-21-2018, 11:43 AM | #22 | |
401
Rep 1,425
Cannot decide whether I should get Euro N52 headrers |
