power steering and RPM question
01-30-2018, 12:08 AM | #1 |
99
Rep 840
i noticed that my 430i loaner doesn't increase the rpm when i am in reverse and have the steering wheel to full lock (when backing out). however, on my e90 335i, the rpm jumps high enough to accelerate the car slightly (backing up and experiencing the car wanting to jolt backward kind of feeling with foot slightly on the brakes). it's annoying. was wondering if something is wrong with my pump or rack, or its in need of a proper bleeding procedure? i've done a "drain and fill" about three times using the turkey baster method into the ps reservoir and that was it. was wondering if you guys experience the same...thanks in advance!
01-30-2018, 01:55 AM | #2 |
20
Rep 100
I have the same "surging" problem. Seems to be pretty common in our cars. I've sadly just learned to live with it. Maybe something will come of this thread though. Following for a chance at a fix.
01-30-2018, 07:44 AM | #3 | |
BMW Portland
224
Rep 524
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
01-30-2018, 04:37 PM | #4 |
174
Rep 614
It's not because it's an electric assisted rack vs. hydraulic. It's a known and common issue on E-series N55 cars. My 2008 N54 335i did not experience this phenomena nor did my 2010 N54 E60 535i Xdrive, both of which used hydraulic racks. My 2011 335i has this issue along with startup idle surging. My dealer acts like they don't notice it/can't duplicate it and therefore will not even attempt to diagnose it. Some people have had success updating their DME at the dealer to get rid of both issues.
01-30-2018, 08:20 PM | #5 | |
BMW Portland
224
Rep 524
01-31-2018, 01:55 PM | #6 |
174
Rep 614
01-31-2018, 01:59 PM | #7 |
Member
159
Rep 269
Drives: 2012 E92 335i M-Sport
This is one of the many reasons BMW switched to electric steering. A fix for this would be raising the idle RPM, but MHD does not allow us to do that yet.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | MHD Stage2+ ACN91 OTS Map | K&N Drop-in | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | xHP Stage 3 | Euro Headlight Switch | Avant Garde M359 | Michelin PS4S |
01-31-2018, 03:51 PM | #8 |
BMW Portland
224
Rep 524
No, it was exactly the same. When I flashed the cold start noise reduction, it actually got worse. Below 40 degrees with the cold start noise reduction, if you turn the wheel within 15-20 seconds of starting the car it will try to die.
I have normal coldstart on now, as I feel like the car runs far better after the 15-20 seconds of higher RPM. The steering thing doesn't bother me, as I never has to turn the wheel when the car is stationary.
02-13-2018, 05:40 AM | #9 |
480
Rep 1,600
