01-29-2018, 04:51 PM | #1 |
73
Rep 664
TPMS warning seems to prevent DCT-Off: Heads up
Start of day 2 at Buttonwillow, temps were cold and tires were low because I had adjusted pressure over laps the day before and Low pressure warning came on.
I adjusted pressures back up when I got to the track. On my first session, I turned DCT off (as you do) but after a few seconds the DCT Off indicator on dash went off. At this point the TPMS still hadn't registered that the tires were back up to normal pressure. I tried it again a few times on first lap and it still kept turning off. I pitted after first lap and tried a few more times to no avail, so at this point I decided better to drive with DCT on that waste time in the pits. After about 1/4 of the next lap the TPMS light went off and I was able to switch DCT off. Seems like you need to clock a couple of miles to reset the TPMS.
01-29-2018, 04:57 PM | #2 |
802
Rep 1,400
That's strange. I have an 18 LCI that I'm currently running a winter wheel/tire package with no TPMS and I am still able to drive the car with no DTC
chief1richard381.00 |
01-29-2018, 06:12 PM | #3 |
73
Rep 664
Might recognize lack of TPMS and behave differently...
01-29-2018, 08:01 PM | #4 |
2542
Rep 3,968
I seem to remember that is correct - that warning is on and you can't turn off that - in fact, maybe sport mode is not avail? I remember at least one other thing not being avail.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
M3 Adjuster7904.50 Aronis2268.50 |
01-29-2018, 09:14 PM | #5 |
375
Rep 507
Also when it is below freezing mine wouldn't change either.
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
01-31-2018, 10:33 AM | #6 | |
2811
Rep 3,695
There is a lot of info in the Track section of the forum that discusses what’s going on and how to work around it. |
01-31-2018, 11:56 AM | #7 |
73
Rep 664
Yes, correct, my bad. I meant DSC.
01-31-2018, 12:29 PM | #8 | |
491
Rep 656
edit- it also remains in this mode until you run TPMS, when i got back in my car the next time on a warm weekend, i had to run TPMS before the warning went away. So basically it "remembers" this issue |
02-05-2018, 10:51 AM | #10 |
10911
Rep 4,541
Drives: 2015 328d xDrive
Here's the pdf to code out TPMS if anyone's interested:
http://f30.bimmerpost.com/forums/sho...8&postcount=24 |
NYC Bimmer259.50 atc556.50 |
02-05-2018, 06:49 PM | #12 |
Life is on the Track, the rest is just waiting.
381
Rep 731
02-05-2018, 07:03 PM | #13 |
2811
Rep 3,695
02-05-2018, 08:10 PM | #14 |
381
Rep 731
Not in my car. My throttle changes between modes. Cant say I've ever noticed any change in steering though. When I start my car up, it is in Comfort, Hit sport, sport plus throttle increases. My last car had adaptive suspension, which changed steering response, I do not notice anything like that on the M2.
02-05-2018, 08:47 PM | #15 | |
2811
Rep 3,695
Maybe it’s a 2018 or latest ISTEP change? |
02-05-2018, 09:36 PM | #16 |
381
Rep 731
It is the case with my 18 LCI. I have no TPM in my winter wheels. I start my m2 and is in Comfort mode. Have a warning on dash which is a small circle. Switch to sport, or sport plus engine revs. I have never noticed any change in steering however in comfort/sprt/sprt plus. It seems the same in every mode to me including when I run summer wheels with TPM's.
02-06-2018, 07:31 AM | #18 |
2811
Rep 3,695
02-24-2018, 11:44 AM | #19 |
793
Rep 1,367
Odd...I thought I was going to have problems after lunch (and letting the car cool down) as I checked pressures and they were all around 25psi...went out on tracked with disabled DSC and had no issues. I took a lap to warm everything back up to track temps...
Never experienced limp mode in the car all day... |
02-24-2018, 01:25 PM | #20 | |
2811
Rep 3,695
Trying to figure out if BMW updated the software and this problem is now gone from pre-LCI cars. |
02-24-2018, 03:45 PM | #21 | |
793
Rep 1,367
Haven't touched iStep but here is mine: It's also a Performance Edition but I honestly don't think the ECU code is any different |
02-24-2018, 04:12 PM | #22 |
2811
Rep 3,695
Got it. Mine is Oct 2016. Planning on doing an ISTEP update before I get on track this year. Will see if it changes anything.
