Trouble tracking down oil leak.
01-29-2018, 10:11 AM | #1 |
146
Rep 295
January 31 UPDATE: Looks like I may have had a pocket of oil somewhere that I missed during cleaning. Wiped off the oil residue, sprayed the area down with a hose and dried it off. Drove about 50 miles and no signs of oil leaking. Talk about a great feeling!
Thanks again for the replies, it was much appreciated. Just finished a fairly substantial job on my 2011 N55 335i xdrive and took it for a quick 5 mile drive last night. Everything felt great except I have an oil leak that I cannot track down. Keep in mind everything had been scrubbed down with simple green and brake cleaner, so any visible oil residue occurred in the 15 minutes I let it idle and during the brief test drive. After getting the car back in the air last night I looked everything over and noticed a little oil at the bottom of the transmission/motor housing location (can see on the pictures) wiped everything down. Checked again this morning and took these pictures. At first I thought it was coming from the oil pan gasket so I ordered that last night. After looking at it this morning, there is fresh oil about 12" above it. The VCG was done recently and I cannot see any signs of it leaking (looked with LED flashlight/mirror combo). When the VCG originally failed, it smelled horribly because the oil would drip on the turbo housing. As you can tell from the under body (first pic), the oil leak was fairly substantial but I attributed that to the OFHG leak. No burning oil smell these past few months of driving the car. Fresh oil appears to be coming from well above the oil pan gasket on the turbo side of the motor. The underside of the turbo manifold where it mounted to the block looks a little wet as well. Front of the motor and drivers side (below intake manifold) are bone dry. Also everything around the oil filter housing is bone dry too. I also popped off the plastic transmission cover to see if there was any oil residue from a blown rear main seal but everything is dry in there (at least from my vantage point). VCG replaced by BMW dealer in fall of 2016 (15k miles ago) I just replaced: -Oil Filter Housing Gasket -Oil Cooler Gasket -new Front Diff/Transmission/Transfer Case/Rear Diff fluids -New water pump/thermostat/coolant -New serpentine belt, tensioner, pulleys. -Oil change Really stumped here and any suggestions would be hugely appreciated! The first pic of the under body was to show how bad it was before I tore into it. second pic is the front of the motor, bone dry but was a mess before due to the OFHG. Third pic is below the intake manifold, bone dry but was also a mess due to the OFHG. Fourth pic and down are all the pictures I took this morning of the current leak. Last edited by carguy138; 01-31-2018 at 03:52 PM.. |
01-29-2018, 07:02 PM | #3 |
146
Rep 295
01-29-2018, 08:12 PM | #6 |
139
Rep 227
Possibly one of the turbo oil lines are leaking?
Like #2 here: http://www.realoem.com/bmw/enUS/show...diagId=11_4474 Could maybe just replace the leaking o-ring if that's all it is. Other than that it would probably be the oil pan or rear main^ |
carguy138145.50 |
01-29-2018, 08:56 PM | #7 | |
146
Rep 295
I have the oil pan gasket/bolts on the way and have been reading up on the job. Do able but would prefer not if possible. Same with the rear main seal. That looks like a royal pain. Last edited by carguy138; 01-29-2018 at 09:23 PM.. |
01-30-2018, 05:29 AM | #8 |
480
Rep 1,600
Rear main is easy. Sump gasket on an Xdrive is a mission.
Before you panic too much, id suggest taking the belly shields off and cleaning again. Use a good chemical degreaser, hose it off (dont let it sit for long periods as many degreasers attack aluminium), let it air dry then brake cleaner. Focus on the areas under the intake manifold as there are many pockets where dirt and oil will pool once you hit it with degreasing agents. It literally is a case of chasing away the dirty liquid with fresh brake cleaner. Compressed air helps but just be careful not to accidentally find a 12v positive connection My guess is that you had a few big puddles of dirty liquid and driving the car has shifted it. Airflow into the engine bay and from the fan will blow it all around. |
carguy138145.50 |
01-31-2018, 01:32 AM | #9 |
485
Rep 599
54k miles and you already replaced VCG, belts and now oil pan gasket?
is your car stock? I'm surprised to see this many issues on a n55 x drive
Vermillion Red
01-31-2018, 03:54 PM | #10 | |
146
Rep 295
01-31-2018, 04:00 PM | #11 | |
146
Rep 295
Car runs well but unfortunately cheap BMW rubber/gaskets are the problem. One would think the added expense to fix the problem (seems to happen on ALL platforms) would serve them well in the long run. Just a shame that they generally make a solid car but completely cheap out on the rubber/gaskets. If they took a tenth of what they spend on free drinks/food in the dealer waiting rooms and applied it to creating much longer lasting gaskets, they would be very well served. Increased perception of reliability by consumers and less waste (all the fluids/labor/cleanup/logistics/etc). Fortunately my car has been pretty good but after 54k miles I've had to replace the Valve Cover Gasket, Oil Filter Housing Gasket, and Oil Cooler gasket. |
