E92 335xi (N55) Hesitation backfiring no codes
01-25-2018, 03:28 PM | #3 | |
BMW Portland
224
Rep 524
Does this happen on Map 0? |
01-25-2018, 07:59 PM | #4 | |
104
Rep 263
01-25-2018, 08:01 PM | #5 | |||||
104
Rep 263
01-25-2018, 08:22 PM | #6 |
BMW Portland
224
Rep 524
Could potentially be the LPFP. I was going to say coils, but even if you have a bad coil, it will still rev out and def throw codes.
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
01-25-2018, 08:52 PM | #7 |
32
Rep 373
This is what my car has been doing - I usually let off the throttle when I feel them coming on but if I continue holding the pedal down the car goes into limp mode and shuts off cylinders. Super frustrating!
2011 335i sedan 6MT, 515whp/530wtq. Pure Turbo Stage 2, Motiv SST TwinDisk Clutch/FW, Motiv Flash, AA 4" DP, ER FMIC, AA turbo-back exhaust, Quaife LSD, ST Coilovers, BMS Intake, UUC DSSR+SSK, ER CP, BMS CDV, BMS OCC, Arkym CF trunk
01-26-2018, 09:25 AM | #8 |
718
Rep 1,753
Gotta love these posts. Could be this could be that. Could be 100 different things...
Get codes .. lets stop assuming NO CEL doesnt mean no codes.. there will be shadow codes for sure.. |
01-26-2018, 12:52 PM | #9 | |
Member
159
Rep 269
Drives: 2012 E92 335i M-Sport
Here is one of my logs as an example (notice the throttle closure and hpfp not hitting its req target): https://datazap.me/u/toome/mhd-stage...=2-17-18-22-23
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | MHD Stage2+ ACN91 OTS Map | K&N Drop-in | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | xHP Stage 3 | Euro Headlight Switch | Avant Garde M359 | Michelin PS4S |
01-26-2018, 06:55 PM | #10 | ||
104
Rep 263
I have some codes: 2BEE high fuel pressure 2BF8 rail pressure sensor permanently stuck 2c01 high fuel pressure 2D15 oxygen sensor after cat 2EE2 combustion misfiring 2EE6 combustion misfiring 2EE9 combustion misfiring 2EEC combustion misfiring 2EF3 combustion misfiring 2EF6 combustion misfiring 2EFF misfire cinder 1 2F00 misfire cylinder 2 2F01 misfire cylinder 3 2F03 misfire cylinder 4 2F04 misfire cylinder 5 2F05 misfire cylinder 6 |
01-27-2018, 12:59 PM | #11 | ||||
104
Rep 263
01-27-2018, 01:53 PM | #12 |
19
Rep 151
What fuel are you running?? Assuming your plugs and coils are healthy, there are usually two things that cause this; Throttle Closures or Fuel System limits. I've spent hours chasing these issues away from my car. For me it was fuel system limits trying to run E40. Even with solid single-gear pulls, the car would break up post shift when it went into open loop. For my car, I've got to keep loads at 190 or less and run no richer than 12.5:1 afr. If any instance occurs that doesn't meet those limits, I get misfires.
2011 335xi M-Sport | MHD E40 | VSRF DP/CP | Wagner IC | GFB DV+ | xHP Stage 3 | Dinan/Koni/UUC
01-27-2018, 02:51 PM | #13 | |
104
Rep 263
01-29-2018, 01:08 PM | #15 | ||
104
Rep 263
https://datazap.me/u/chris-barta/log...og=0&data=4-14 |
01-29-2018, 02:22 PM | #16 | |
718
Rep 1,753
So from that 1 log i can see that the HPFP is not holding pressure. When you opened throttle there it went up to 1800 (which should have maybe been even higher) then dips to 900 which it should not. You have issues with you HPFP. ITs weak sort of say.. Not holding pressure well. |
01-29-2018, 02:25 PM | #17 | |
718
Rep 1,753
https://datazap.me/u/pladi/log-15153...0&data=2-16-17 Graph throttle and fuel rail pressure. See how your dips and this stays up.. |
02-05-2018, 04:22 PM | #22 |
324
Rep 2,014
Were you ever able to figure out the 2bf8 code?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
