2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Help coding 6NS/6NL
      01-20-2018, 11:56 PM   #1
ssrriivv
9
Drives: M240i xDrive coupe
Help coding 6NS/6NL
Hi guys,
So I'm new to whole coding game, but I thought I'd take a stab at coding enhanced bluetooth on my 17 M240i.
First I'm confused whether I should use 6NH or 6NL. I just went with 6NL because somewhere it said that if you have NBT_ENTRYNAV you should use 6NL.
So I coded the FA from 6NH to 6NL, and wrote that successfully to the car. So now if I read FA, it does indeed show 6NL.
Now I read that I needed to VO Code the NBT unit. So I tried that, and I keep running into the following error.
Code:
cdDeploy FinishedWithError cafd_00000ded-003_015_028 NotExecutable
I have been looking around for help and can't seem to find anything other than psdzdata being out of date, but I am using the latest one anyway, so I don't think that is the issue.
Does anyone have any thoughts?
      01-21-2018, 07:02 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
PSdZ is fine. Likely something in FA that E-sys does not like.
      01-21-2018, 10:32 PM   #3
ssrriivv
9
Thanks, I figured it out
      03-31-2018, 03:12 PM   #4
MarSchwar
Drives: BMW i3 BEV
HI, I have 2014 i3 BEV and options 609,645,655,6AC,6AP. I was trying to add 6NS,6AM,6CP,6NR. Coded it without errors but when read ECU again, nothing new was added. I did code with bimmer code to get 2 phones and receive txt message but was wondering if with VO coding it would work better. Perhaps can get a calendar? Any anybody help with advice? txt
Tags
coding
2addicts
